Thanks Dave,
I saw this too late to call, but I did some calling and more research.
Standard SBM/BBM bolt circle is 2.811" give or take a thousandth
![](/ubbthreads/images/graemlins/smile.gif)
Mopar center register is 2.25"
Industry standard blower pulleys are 2.75", 2.76" or 2.782" bolt circle (depends where you check), with a 2" center register.
There used to be Weiand style pulleys with a 2.25" center register. Supercharger USA show them as an option.
http://www.superchargerusa.com/weiand_pulleys.htmHowever, they don't say what the bolt circle is. They (probably more like a "he") are away until May 3rd, so I'll call them then and ask. I also saw some ebay seller that claims he actually makes the pulleys, so he can custom make them. Sent him a question about that.
I called several blower shops, the ones I got a hold of, told me they only deal with the industry standard stuff.
I couldn't get a hold of Littlefield, Mooneyham or BDS yet, so I'll try to see if they can help.
I'll update here when I get an answer. Not that it should matter to anyone building a blower only engine...I just want to use a system that will allow me to use the engine without a blower (when the blower gets migrated to another engine for example).
Ran
