Page 2 of 3 1 2 3
Re: Wanna hear what boost can do? [Re: dizuster] #677015
04/23/10 11:58 AM
04/23/10 11:58 AM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Wooo!!! That's some exciting encouragement there!!
Re: Wanna hear what boost can do? [Re: BobR] #677016
04/23/10 09:04 PM
04/23/10 09:04 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
Well, get us all excited will ya!
Last time I had my Challenger to the track it ran a best of 13.9 @ 100 with an old stock 1968 375 horse 440 with headers and a 750 Holley.
I wonder what I'll pick up with a few PSI thrown at it?
Rule of thumb is approx 30 hp per boost pound.
Is that for centrifugals as well? I'm getting 12 psi intercooled, does that really equate to 360 hp? seems high to me.
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: Wanna hear what boost can do? [Re: whiplash] #677017
04/23/10 09:29 PM
04/23/10 09:29 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I would assume that a centrifugal charger takes power to drive it too.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Wanna hear what boost can do? [Re: whiplash] #677018
04/24/10 02:39 AM
04/24/10 02:39 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
I agree, that's high in my case as well. It is entirely based on the top-end of the motor. My heads are extremely restrictive, and boost is nothing but A MEASURE OF RESTRICTION. A 500 horse NA motor with good heads is going to respond to boost alot better than a stocker type combo.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Wanna hear what boost can do? [Re: topfueldart] #677019
04/24/10 09:48 AM
04/24/10 09:48 AM
Motor City
Shaker223 Offline
Shaker223  Offline
Motor City
My combination is basically the same, except in mopar land. Its a 318 with stock small valve heads, a 467/494 Crane Cam, Air Gap and 650 DP. 3.54 gear, and 28 inch tire in a 3350 lb plus me and junk in the trunk makes it 3550 raceweight, 68 Dart. The heads are a major restriction, but on 13 lbs the car just went 11.48 @ 120 on pump gas with water/meth. Without boost, im sure it would be a mid 14 second car.
Except I built the kit, didnt buy it.
I wanted to show what could be done with a cheap motor, im willing to bet an edelbrock head swap would be worth 100 horse, easy.
Same experience here....you all know how fast a stock slant 6 is. Put about 30psi into it and it reponds very well! 11.77 @ 116....That was at 3500lbs. Best mph was just short of 118. That's almost 450 at the crank.
Talk about restriction...the stock head flows around 120cfm on the intake and 90 on the exhaust. The stock rockers are about a 1.39 ratio and the cam lift at the valve is around .365 lift.
Re: Wanna hear what boost can do? [Re: rabid scott] #677020
04/25/10 05:30 PM
04/25/10 05:30 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Case in point, I went 13.88 @ 98 on 13 lbs with a 4 cylinder Spirit R/T! ( OH yea, 3400 lbs with me in it!)
Re: Wanna hear what boost can do? [Re: topfueldart] #677021
04/25/10 06:49 PM
04/25/10 06:49 PM
Tolstoy, SD
turbo66valiant Offline
Tolstoy, SD
We went 11.04 @ 124 with basically the same car and 318 but .512 roller, Edelbrocks w/ 8 psi boost and 575 Demon. Heads do make a diff!
Later
Ryan
Turbo Slant 6 Valiant 10.74 @ 127.47 6.65 @ 107.80 http://www.youtube.com/user/turbo66valiant
Re: Wanna hear what boost can do? [Re: BobR] #677022
04/28/10 10:26 PM
04/28/10 10:26 PM
SRQ, FL
8valves Offline
8valves  Offline
SRQ, FL
I'm hoping that's a statement in regards to JUST one particular combination you've dealt with?
Because there is no "rule of thumb" for power/psi. All applications vary.
Aaron M
Re: Wanna hear what boost can do? [Re: 8valves] #677023
04/29/10 12:37 AM
04/29/10 12:37 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Absolutely. Since the boost number is just a measure of the amount of air that's NOT making it thru the engine, the same boost number with better flowing heads, cam, intake and carb (TB) will make lots more power.
My existing fuel system would only support a certain amount of power. With my original set of heads - I got to that HP number and fuel limitation at 16 psi of boost. I swapped heads and I actually got more power but ran into the same fuel limitation at 10 psi. Everything else stayed the same, just swapped a better flowing set of heads.
To break it down:
Original heads with 16 psi of Vortech Blower and Intercooled Boost - 11.43 @ 124.24 mph or 34.375 hp per lb of boost.
Original heads with 16 psi of Turbo and Intercooled Boost - 10.98 @ 126.24 mph or 39.25 hp per lb of boost.
New heads with 10 psi of Turbo (all things the same) - 10.74 @ 128 mph or 68.4 hp per lb of boost.
Not all boost is the same.... not all engines are the same. Huge difference with just heads change. While the boost number gives some frame of reference, it's no measure of how many lbs of air goes thru the engine.
Re: Wanna hear what boost can do? [Re: Duner] #677024
04/29/10 06:33 AM
04/29/10 06:33 AM
SRQ, FL
8valves Offline
8valves  Offline
SRQ, FL
It should be stated that the curve of each individual setup for power/PSI is also based upon the actual setup. It is NOT constant.
At the end of the day XXX amount of CFM ends up producing XXX amount of power. What your engine can actually swallow at once will give you the boost it has to run to make said power.
Duner, as much as I like your vehicles, I must say, I'd be blown away (no pun intended) if you raised boost 1 psi and picked up another 68 HP. That's about 20 HP more per PSI than a well designed and optimized system on DOHC 300 or so CID motors that make 400 HP stock and over 1000 HP boosted that I deal with regularly.
Just for reference.
Aaron M
Re: Wanna hear what boost can do? [Re: 8valves] #677025
04/29/10 07:20 AM
04/29/10 07:20 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what they said..i think i said it before...it's about airflow not boost. get the good air/fuel in and as much as you can.
Re: Wanna hear what boost can do? [Re: 8valves] #677026
04/29/10 09:12 AM
04/29/10 09:12 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
I'd be lying if I said I wasn't going to do everything in my power to test that! I have a few more items that need to be purchased before I can make the changes. Right now it's still running on an FMU and 160 psi of fuel pressure thru 24# injectors. I can't raise the pressure any higher and I can't get it to run on larger injectors.... yet.
Re: Wanna hear what boost can do? [Re: 8valves] #677027
04/29/10 11:31 PM
04/29/10 11:31 PM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Just for reference.
I got to thinking about the differences. I don't know what "optimized for boost" would be, but I sure have a bunch of time in my home-brewed port job! LOL
According to my math, the change to better flowing heads basically took my NA numbers from 303 hp to 407 hp - and then you just multiply times the boost number from there. So the question is: Should the hp per # of boost be total? or just what it added? Because if you subtract the NA numbers out of the total hp produced, that's what the boost actually did..... or is that not the way to think of it?
Re: Wanna hear what boost can do? [Re: Duner] #677028
04/30/10 04:57 AM
04/30/10 04:57 AM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Just what it added. Thats why the 68 number was so wrong.
Re: Wanna hear what boost can do? [Re: topfueldart] #677029
04/30/10 09:03 AM
04/30/10 09:03 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
Oh, OK. Then it should be more like 27.7 hp gained per lb of boost in my current configuration. That makes more sense anyway.
Re: Wanna hear what boost can do? [Re: 8valves] #677030
05/01/10 06:19 AM
05/01/10 06:19 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Yes.
I can vouch for the 2.2 / 2.5 engines, depending on the setup 10 to 20 hp per pound of boost is normal.
The 8 valve heads flow pretty poor and turbine and intercooler restrictions play their parts as well.
Gary
Re: Wanna hear what boost can do? [Re: gdonovan] #677031
05/01/10 02:16 PM
05/01/10 02:16 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
my car runs 6.2s in the 1/8th
493 with around 720hp
i just ported a set of ls1 heads for my friend that put a tiny turbo on his car. he went 6.38 the second time out with no tuning.
I'm pissed! he has $1500 in the motor and $2500 in the turbo and fuel system.
for the past week i'm really starting to think about building a low dough new hemi with twin turbos. i have very knowledgable friends that do turbo stuff and i'm thinking very hard about it now.
another factor is, if i ever wanted to go faster with a bb i need a block. thats atleast 3k right there
Re: Wanna hear what boost can do? [Re: sixpackgut] #677032
05/01/10 03:28 PM
05/01/10 03:28 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Whoever says there is no replacement for displacement, has never ridden in a fast blown/turbo car!!
Re: Wanna hear what boost can do? [Re: topfueldart] #677033
05/01/10 04:54 PM
05/01/10 04:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
ummm yeah but do the same thing to a bigger motor and get BIGGER results.
Coming soon!!!!
Re: Wanna hear what boost can do? [Re: Mr.Yuck] #677034
05/01/10 05:48 PM
05/01/10 05:48 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Yea but I get 30 mpg off boost .
Page 2 of 3 1 2 3
