oil pressure problems #67635
06/04/08 07:30 PM
06/04/08 07:30 PM
Queens N.Y.
diesel1114 Offline OP
super street
super street
Queens N.Y.
hey guys just got the new engine running but the oil pressure is high at idle when hot like 65 -70 psi the egine is a 440 and i have a high volume melling oil pump does anyone have any ideas or possible a suggestion of what i can do ? i was thinking if there is a kit for relief valve and spring inside pump
thanks
john
JOHN WS23L8GXXXXXX
Re: oil pressure problems [Re: diesel1114] #67636
06/04/08 07:53 PM
06/04/08 07:53 PM
Palm Coast, FL (near Daytona B...
Blown_Hemi Online content
Blown_Hemi  Online Content
Milodon has an adjustable pressure regulator for the oil pump.
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: oil pressure problems [Re: Blown_Hemi] #67637
06/04/08 08:09 PM
06/04/08 08:09 PM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Once the motor breaks in It will go down .Use thinner oil
Re: oil pressure problems [Re: Scamp408] #67638
06/04/08 08:38 PM
06/04/08 08:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What's the pressure at 3000rpm?
Re: oil pressure problems [Re: diesel1114] #67639
06/04/08 11:28 PM
06/04/08 11:28 PM
ST clair shores MI
moretoys Offline
moretoys  Offline
ST clair shores MI
Do you have a deep pan on it??High volume pumps are not good for standard oil pans,too much oil up top, not enough down low.try a standard pump.or a weaker spring.(large nut on the back side of the pump.It is possible to do it on the car.Fresh engines will have higher oil psi.If running a 15w40, 20 w 50,etc,A thinner oil will also help.10 w 30.put some miles on it,break it in.did you change it after the cam break in??should to get the assy lube out of the oil.
How are you reading the psi. manual guage or the factory stuff.factory stuff could have an error.Make sure you have a good filter on it.I have had fram's burst at 90 psi.use a good filter,wix,napa,purolator.
Re: oil pressure problems [Re: moretoys] #67640
06/05/08 06:51 AM
06/05/08 06:51 AM
Queens N.Y.
super street
super street
Queens N.Y.
ok well here is the deal so far i do have a stock pan becsaue the car sits very low . also i am using 10-30 oil and yes i did drain the oil after break in and i ma using autometer gauges to get reading , now i like teh idea of changing that spring , do u think its the better idea than changing pump ? and does anyone have the part # for it? or is it better to chang the pump , its brand ne its would be a pitty to change it
JOHN WS23L8GXXXXXX
Re: oil pressure problems [Re: moretoys] #67641
06/05/08 01:15 PM
06/05/08 01:15 PM
own private Idaho
N
ngpSatellite Offline
N
own private Idaho
whats a good pressure at idle?? and at 3000rpm? I have close to 60psi at starup...is that to high? when it gets hot it will go down to 40psi at idle. I also put the same oil pump on a 69 383hp... the autoparts store guy was telling me the hiher the better??
Re: oil pressure problems [Re: ngpSatellite] #67642
06/05/08 02:41 PM
06/05/08 02:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
40 psi at a warm idle is great. Rule of thumb is 10psi per 1000 rpm. With 20 being ok at hot idle.
Re: oil pressure problems [Re: diesel1114] #67643
06/05/08 03:21 PM
06/05/08 03:21 PM
own private Idaho
N
N
own private Idaho
John, call melling tech support they should have your answer about the spring part number the number is.... Customer Service: 517-787-8172
Re: oil pressure problems [Re: diesel1114] #67644
06/05/08 04:44 PM
06/05/08 04:44 PM
Richmond Va, KeislerTKO 60...
V
VanishPt Offline
VanishPt  Offline
V
I went to Advance Auto and went to the HELP section. They sell a mixed pack of copper washers, one of which will just screw onto the threads of the cup ( holding the spring in the oil pump). It is .050 thick. I added it to the stock washer and it brought my cold pressure down from the low to mid 80's to upper 70's.. I was able to change it from the top side of the motor
Re: oil pressure problems [Re: VanishPt] #67645
06/05/08 10:52 PM
06/05/08 10:52 PM
Western Colorado
3
340Scamp Offline
340Scamp  Offline
Western Colorado
with scamp408
Re: oil pressure problems [Re: 340Scamp] #67646
06/05/08 11:10 PM
06/05/08 11:10 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
What is being seen here, is that a high volume pump isn't needed on a freshly machined motor.
The clearances are tighter. A new stock pump will move more oil, and make more oil pressure than you can ever use.
I recently reringed a 440, and put fresh bearings in it. No machining, and the clearances checked to be around .002 to .0025 on the mains. .002 on the rods, and cam bearings were not changed.
I used a stock oil pump.
The pressure relief stuck in it at start up, so it was full pressure.
It made so much pressure at an 800rpm idle, that it pegged the gauge and wrecked the sender, and BLEW the filter right apart.
SO.... in a motor with high clearances (compared to an actual rebuilt/machined motor which would have main clearances closer to .0015) and only a standard volume pump, it STILL moved enough volume of oil, to make enough oil pressure to destroy a filter, at only 800 rpm. I'd be surprised if it was anything less than 100 psi.
All this said, I'll never buy a high volume oil pump again. At least not for a fresh motor.
I'll gladly put one on a motor that is miled out, and has oil pressure problems.
