Re: Sandblasting manifolds...
[Re: 440newport]
#67499
06/04/08 04:16 PM
06/04/08 04:16 PM
Posts: 21,091 Niles , Ohio
therocks
Niles , Ohio
Tape it off and bead blast them.Sand is real abrasive.Rocky
Chrysler Firepower
[Re: 440newport]
#67503
06/04/08 07:55 PM
06/04/08 07:55 PM
Posts: 8,928 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
And cast iron is real f***ing hard!
Sandblast them. Anything else on rusty cast iron is like pissing on a forest fire. Taping the flanges with a couple layers of duct tape will save the machined surfaces. Don't skimp on tape, 5 layers will do more good than harm. Trim the excess around the flanges so the blasting doesn't have a big edge to catch and blow the tape off. Cut the openings out and tell the guy to shove the blasting nozzle down the ports to get rust and carbon buildup out of there too!
[Re: Stanton]
#67504
06/04/08 08:03 PM
06/04/08 08:03 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
You want to use aluminum oxide on rusty cast iron manifolds. Bead blasting leave steh surface smoother, but it will take forever when used at the correct pressure.
[Re: MLR426]
#67507
06/05/08 12:42 PM
06/05/08 12:42 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
The machine shop I work for glass beads them, and they come out fine.
And why not, time is money and as the saying goes, "there's a sucker born every minute". If I were some scumbag charging by the hour I'd bead blast them too!
Sandblast 'em and GIT 'ER DONE !!!
