Setting up practice tree question
#674404
04/19/10 08:07 AM
04/19/10 08:07 AM
Posts: 1,086 Baton Rouge, La.
StandOnIt
Baton Rouge, La.
Its asking for my rollout time. I have a 24.5" tall front tire, 437 hp, 4.10 rear gear and a 1.58 60' time. What would be my aprox rollout time? I can't seem to find a calculator for this anywhere online. Thanks guys.
76' Volare, 5.9 magnum w/Iron heads. New best 10.68 at 123 mph 1/4 mile.
Re: Setting up practice tree question
[Re: StandOnIt]
#674407
04/19/10 09:15 AM
04/19/10 09:15 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Call the manufacture, they can tell you
[Re: StandOnIt]
#674410
04/20/10 03:15 PM
04/20/10 03:15 PM
Posts: 7,506 Az
Crizila
Az
"Factory" setting on my Pocket Pal is .320. The best way I have found to adjust roll out is to practice with the factory setting. When you get pretty consistant with your practice tree set at .320, apply it to the track. Try to stage shallow and the same each time to eliminate that variable. Make some passes and see what your reaction times are. If you are within say .030, .320 is a good rollout time for you and your car. If you are slower than .030, dial in less rollout time on your practice tree and vise versa. Believe it or not, Driver rollout time is usually very consistant around .210.
Fastest 300
