Ball joint replacement questions...
#673945
04/18/10 05:46 PM
04/18/10 05:46 PM
Posts: 4,617 In the tower
RonTheAnnouncer
In the tower
I'm a complete rookie when it comes to working on suspension. The ball joints on my 74 Dart are a mess. I need to stay low buck, which means I need to learn...soon! So, is it as fun a job as it looks...what other items should I think about replacing while I'm at it?
Ron H. "Just when you think you have all of the answers...I change the questions!" "Rowdy" Roddy Piper
Re: Ball joint replacement questions...
[Re: RonTheAnnouncer]
#673946
04/18/10 06:18 PM
04/18/10 06:18 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
replace the ball joint with the A arm on the car,,, much easier... now remove the A arm from the car and replace the upper bushings.. loosen the 'NUT' end on the bolt. the excentric is welded to the bolt head end...
I am truckless..
#673949
04/20/10 04:08 AM
04/20/10 04:08 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
Everyone likes to save money, and if you have some skills, you can do well here. The LOWER control arm bushing takes most of the load, so they are usually worn the worst. Leaky slant six engines will drip oil onto the right control arm and soften the bushing until it breaks up and squishes out. V8 engines with leaky power steering boxes do the same to the left side bushings. Replacement of these bushings can be done at home, but I have never tried it. For $20, I let the man do it. You can piece all the parts together at your leisure, but it is far cheaper to but a kit in the factory rubber app. The upper control arm bushings are easy enough to do at home with a quality vise to press them in. I have done several. Regarding alignment, write back when you get to that point. There are several ways to get you close enough to get to an alignment shop without chewing up your tires. I have even had cars that were within specs when they got them on the rack! Pure luck I guess, but I'm not complaining.
