Re: Car went down the track
[Re: VernMotor]
#673161
04/18/10 08:12 AM
04/18/10 08:12 AM
Posts: 6,295 U.S.
moparniac
U.S.
what did his engine dyno at? thats a big car. how heavy is it!
Mopar Performance
[Re: WILD BILL]
#673163
04/18/10 08:22 AM
04/18/10 08:22 AM
Posts: 16,932 NC
440Jim
NC
Went 1.49 60' and 10.53@125mph
Alky: 759 hp @ 7400 rpm 603 ft lbs @ 5800 rpm.
I will have to put that as calibration for that dyno. Whose dyno is it? And as I recall 2800-3000 lbs with driver?
That RPM compared to the peak HP isn't bad. But if the converter is slipping a lot, it will eat up power, especially at the finish line. What is the tire dia, gear, etc. so you can calculate the converter slip?
[Re: 440Jim]
#673164
04/18/10 08:37 AM
04/18/10 08:37 AM
Posts: 16,932 NC
440Jim
NC
7600 rpm, 125 mph Tires are 31's and gears are 4:56's
As someone else posted, that is roughly 19%-23%... Definitely not working correctly in that combo.
Did you double check the trans fluid level, stall check, etc? You should be able to make a tight 8" do the job. But a 9" can be made to do it too.
[Re: 440Jim]
#673166
04/18/10 08:46 AM
04/18/10 08:46 AM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Sorry Dom, we stayed at the track last night so yes, I'm still here and looking to make some passes.
Also got to figure out an elevtrical glitch on the 72 or I'm pushing it back int the trailer
here's the 1/8 mile times first pass was 6.60@103.74 second, 6.7@101.90. third 6.66@102.63
Jim, tires are 31's and the gear a 4:56.
I just hope the wind dies down toady. Yesterday it was terrible. Hard cross wind
[Re: moparniac]
#673167
04/18/10 08:50 AM
04/18/10 08:50 AM
WILD BILL
BROOK PARK, OH
Went 1.49 60' and [Email]10.53@125mph[/Email]
I see why Wild Bill posted he is disappointed! thats coming up a 9.2x on the wallace calc!
I never ran it through the calculator. I've never had any faith in them as I've never seen one close to real word.
I was hoping for high 9.80's low 9.90's myself.
[Re: theclutcher]
#673170
04/18/10 09:17 AM
04/18/10 09:17 AM
Posts: 2,177 ill
dennismopar73
ill
well i wouldnt touch the 456 cam alky he has 8 3/4 stuff is tough enough 31 tall tire be great bill, just fix the converter/ tranny this car should run and run hard towards 9.90s 10.00s dont be disapointed, use this as a challenge,
[Re: emarine01]
#673173
04/18/10 11:29 AM
04/18/10 11:29 AM
WILD BILL
BROOK PARK, OH
Always
On a good note, we went ahead and did the chassis cert anyways, just in case we do get it sorted out I didn't have to pay more later.
Passed 8.50 cert with flying colors
[Re: Thumperdart]
#673175
04/18/10 12:56 PM
04/18/10 12:56 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
Good luck today and if you have the same results no point in beating a dead horse. Get the right vert and get back out there and get those well deserved 9-sec slips......you deserve it...
what,you dont want to hear how his day went? i will listen to ya bill.
[Re: Thumperdart]
#673177
04/18/10 01:25 PM
04/18/10 01:25 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
What I`m saying is that if he has the same results after a few passes chances are he`s not going to go much quicker and he might as well go home , get the new vert and go get those 9-sec slips.
While he's there he might as well have fun and run as many laps as possible even if it ain't nines
Rickster
