Page 2 of 5 1 2 3 4 5
Re: Car went down the track [Re: tboomer] #673121
04/17/10 11:09 PM
04/17/10 11:09 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you are killing us
Re: Car went down the track [Re: MR_P_BODY] #673122
04/17/10 11:10 PM
04/17/10 11:10 PM
BROOK PARK, OH
WILD BILL Offline OP
BROOK PARK, OH
Made 3 passes today, first pass I left the launch and shift settings the same as last year, 3600 and 5800. I shifted real lazy too and it went a 10.47@124mph. Carried the front end good as I felt it come back down. 1.43 60'
Next run we bumped up to 4200 and 6600 and it spun bad off the line. 1.52 60' and ran 10.64@124mph
Last pass we dropped the tires down to 8 psi and got it to hook better, Went 1.49 60' and 10.53@125mph.
We think the conv might be to loose as I'm turning 7600-7700 rpm at the stripe and a soft luanch and short shifting netted the best ET.
I wanted to make another pass but had to get Taylor some runs W her new motor. She lifted big time on the first pass and went 9.60.
Next pass I jetted it up as it was a little lean and she ran it hard but I know she didn't run it all out. Went 8.71 @ 65 mph. Now she used to run 9.20's @ 68 mph so I know she didn't stay in it.
Dying to see how much I'm gonna need to slow her down
Re: Car went down the track [Re: Quicktree] #673123
04/17/10 11:10 PM
04/17/10 11:10 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
C'mon all ready!
Re: Car went down the track [Re: DoubleD] #673124
04/17/10 11:11 PM
04/17/10 11:11 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
well do the dyno numbers lie or not?
Re: Car went down the track [Re: DoubleD] #673125
04/17/10 11:11 PM
04/17/10 11:11 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Times up!! Here it comes!!
Oh No he has to wear the dress again
Is that SFI certified it looks to be his size
Re: Car went down the track [Re: Dart1031] #673126
04/17/10 11:13 PM
04/17/10 11:13 PM
BROOK PARK, OH
BROOK PARK, OH
Dam Ted, I had a lot to type and had to chase down the time slips so I had everything accurate.
Re: Car went down the track [Re: Quicktree] #673127
04/17/10 11:13 PM
04/17/10 11:13 PM
ill
dennismopar73 Offline
ill
he posted at 10 min till
now 13 min past the hour
he is just sitting there watching these replies
laughing ay us
knowing it is eating at us
Re: Car went down the track [Re: WILD BILL] #673128
04/17/10 11:15 PM
04/17/10 11:15 PM
tboomer Offline
tboomer  Offline
You are forgiven,My freind!! Everything will be better by morning!! Serious...What is the convertor??
Re: Car went down the track [Re: tboomer] #673129
04/17/10 11:17 PM
04/17/10 11:17 PM
BROOK PARK, OH
BROOK PARK, OH
Conv is a borrowed TA 8"
I was really hoping it would like the new set up but I guess you can't have everything.
Re: Car went down the track [Re: tboomer] #673130
04/17/10 11:20 PM
04/17/10 11:20 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Bill, glad to hear it went down the track and you didn't break anything. Now the fun part is coming trying to get it tuned just right and trying different launch and shifting patterns to see what works best. I do think you are spinning it way too much at the top end.
Russ
Re: Car went down the track [Re: WILD BILL] #673131
04/17/10 11:20 PM
04/17/10 11:20 PM
MR_P_BODY Offline
MR_P_BODY  Offline
What did it flash to with the new set up... the MPH
and ET fall in line(within 1 MPH)
Re: Car went down the track [Re: MR_P_BODY] #673132
04/17/10 11:25 PM
04/17/10 11:25 PM
tboomer Offline
tboomer  Offline
What was the T/A convertor designed for..PS...You are Blue again!!
Re: Car went down the track [Re: MR_P_BODY] #673133
04/17/10 11:27 PM
04/17/10 11:27 PM
PA
moparacer Offline
moparacer  Offline
PA
7700 at the stripe??
WAT?!?!
Like, not planning on doing that too many times are ya?
Whats the gear ratio and tire size on your combo?
124 does seem close for mid 10's. A little shy but close.
I just went 10.79 @ 122 in my old car today.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Car went down the track [Re: WILD BILL] #673134
04/17/10 11:27 PM
04/17/10 11:27 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Well, at least you got some data to work with for next time. What were your increments when you went that 10.96 and the 11 0`s.
Re: Car went down the track [Re: Thumperdart] #673135
04/17/10 11:32 PM
04/17/10 11:32 PM
BROOK PARK, OH
BROOK PARK, OH
I was turing 120 when made that 10.96 pass.
Tires are 31's and gears are 4:56's.
Half a second for 5 mph seems a little off to me?
Re: Car went down the track [Re: moparacer] #673136
04/17/10 11:34 PM
04/17/10 11:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hard to say exactly what happened but the mph and et do seem close to right on. Granted a converter can make a big difference but to go from mid 10`s to the predicted low 9`s is doubtfull. Not baggin just stating my opinion. On a good note you destroyed your old et and have a new best w/more to come. Oh, and your 8 3/4 held up just like I knew that it would.
Re: Car went down the track [Re: WILD BILL] #673137
04/17/10 11:36 PM
04/17/10 11:36 PM
Q
Quicktree Offline
Quicktree  Offline
Q
well I was pretty dang close with my 10.60 guess but I know you have a bunch more in it when you get everything sorted out. really not bad for your first time out. you will figure it out
Re: Car went down the track [Re: Quicktree] #673138
04/17/10 11:41 PM
04/17/10 11:41 PM
BROOK PARK, OH
BROOK PARK, OH
Thanks guys. I do appreciate the kind words
However, both Scott and I had our thoughts on what it would run and both of us are diassapointed at this point.
I know first hand how much difference a conv can make. I saw it happen when my old one went away.
I personally think there is more in this.
Re: Car went down the track [Re: Thumperdart] #673139
04/17/10 11:41 PM
04/17/10 11:41 PM
Tennessee
727builder Offline
727builder  Offline
Tennessee
Best part is... It's all still in one piece. Glad the 8 3/4 help up. I would be planning a dana for her soon. Who won with the closest guess?
Re: Car went down the track [Re: moparacer] #673140
04/17/10 11:42 PM
04/17/10 11:42 PM
ill
ill
mph slow
et off
way to rpms
i drove car last year 67 coronet 3800# 440
ran 11.13 best at 122+ mph
rpms around 6850
but it wouldnt move out gate 60 ft was horriable
best 156
sound like got just a little more work to do bill,
converter /tranny issue
i am still going to stick with my predictions
about the combo once it gets right
