Timing sprocket marks #67271
06/04/08 08:52 AM
06/04/08 08:52 AM
Snowing in the north!
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
While I have my engine torn down I am checking the
timing sprocket marks with TDC etc. Here's the weird
thing. The alignment marks are off a little, maybe not quite a gear tooth, or maybe just. I find TDC on fire stroke and check that with valves / cam timing
and it seems correct. Both valves closed and preload
set right. Used a dial indicator to exactly find TDC and same with valves so I know the two are where they should be. Whats up? Can the marks be "off" somewhat on the chain set?
Re: Timing sprocket marks [Re: Dart 340] #67272
06/04/08 09:43 AM
06/04/08 09:43 AM
places
79powerwagon Offline
places
Yes, it happens all the time, thus the use of offset keys, eccentric bolts, etc. It it really only important if you're building a high-speed/high-power race engine. A stock street engine won't be an issue. You think they get that precise at the factory when they're throwing that stuff together?
Re: Timing sprocket marks [Re: Dart 340] #67273
06/04/08 09:53 AM
06/04/08 09:53 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
yes marks can be off. i recently built a 360. used a Mancini roller set and the marks were 4 teeth off. that put my valves 68 degrees adv. till it broke a valve face off and exploded my motor. each tooth on the crank gear is 17 degrees. i am not saying anything bad about Mancini because everybody gets a bad part sometimes. it's weather the make it right or not that counts. at this point they are working with me. so compare yours to other brands to make sure yours is marked right. i will enclose a pic (if i can downsize it enough) to show correctly marked and not.
65 Cuda 360,3.23 SG-13.97 @99.4, 88 D100, 2000 Kota Qcab, 71 Duster 416 11.84 @110., 73 Imp ,(2)72 & (1)71 Dart Swingers
GarysMocars Legendary Dealer
Re: Timing sprocket marks [Re: 79powerwagon] #67274
06/04/08 09:55 AM
06/04/08 09:55 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Well that's what I figured, but if the centerline of the lobes lines up with TDC I can't see how it would
matter too much. I know after market parts can vary also. Hell I'm just happy I tore it apart to see what was wrong before real damage happened.
You know, you really should use the right width key in the key slot too..... well water under the
bridge, it's fixed now.
Thanks for the info.
Re: Timing sprocket marks [Re: Dart 340] #67275
06/04/08 10:03 AM
06/04/08 10:03 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
yes i agree. i didn't have another gear set around when i put it together to check. so this is what happenes when you run 4 teeth off.
Re: Timing sprocket marks [Re: 65cuda] #67276
06/04/08 10:48 AM
06/04/08 10:48 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Holy crap, that's awful!
My marks are off like one tooth-ish. But I did check
valve position and tdc and it's where it should be
when both valves are closed so I'm going to assume
this is good enough to go. The marks are just kind of weird on this set. they look more like the letter o than a real mark......
Very sorry your engine crashed. Hopefully it's on the mend now.
Re: Timing sprocket marks [Re: 65cuda] #67277
06/04/08 10:55 AM
06/04/08 10:55 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Wow, that is a crappy marked crank sprocket, although it is the dot by the keyway that is just indicating which of the 3 keys are the "straight up" position. There looks to be a faint dot mark shown more towards the outer edge of gear around 4 teeth to the left of that key. Never use the mark at keyway to line up with the cam sprocket dot, and another good reason for dialing in cam.
Re: Timing sprocket marks [Re: buildanother] #67278
06/04/08 11:10 AM
06/04/08 11:10 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Isn't dialing in pretty much the same as finding TDC and center of the lobe? So would you have to use and offset key if it is off?
Re: Timing sprocket marks [Re: buildanother] #67279
06/04/08 11:19 AM
06/04/08 11:19 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i agree there is a speck of a mark in the correct place but i couldn't see it when i put it together. they put the big mark matching the cam gear on the keyway. if i built motors offen i might have thought hey the mark isn't always on the keyway. but who am i to question they way they make gears. heck there is 3 keyways. i know what they are for but i couldn't tell you where they should put the correct mark. all i wanted to do was make it dot to dot.
this cam pistons and rockers were all happy together before. so i didn't worry about degreeing it. i bal. the bottom end and put on a new timming set, BM flex plate,new harm. bal. and thought i was good to go. as you can see there isn't much left of my KB107.
Re: Timing sprocket marks [Re: Dart 340] #67280
06/04/08 11:22 AM
06/04/08 11:22 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Maybe in a round about way. I guess you can do it that way if your just looking for O degrees advanced/retarded. But I wouldn`t. Mike
Re: Timing sprocket marks [Re: 65cuda] #67281
06/04/08 11:24 AM
06/04/08 11:24 AM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
Dart 340 i looked at the valves at TDC too and they were closed. so i guess that isn't a good indcator.
Re: Timing sprocket marks [Re: 65cuda] #67282
06/04/08 11:52 AM
06/04/08 11:52 AM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
So how did you have a collision then?
I checked mine after the gears and chain were installed. I don't see how it can hit if you verify that piston TDC and valve opening / lobe center are ok? Just trying to learn. I have a degree wheel collecting dust somewhere... never used....
I needed to replace a stripped out eccentric key so
I never changed the alignment of the gears just slid a new (right size) key in. I wanted to check what someone else had done way back when because they did not install the cam retaining bolt correctly.
Re: Timing sprocket marks [Re: Dart 340] #67283
06/04/08 12:07 PM
06/04/08 12:07 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
i don't know i guess it was just advanced enough to hit it as it was closing. it ran petty good i just had some lifter noise. and i was trying to figure that out. got 39 miles on it doing 45 MPH when BANG and everything was quite and i was coasting.
Re: Timing sprocket marks [Re: 65cuda] #67284
06/04/08 12:15 PM
06/04/08 12:15 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Good god, that is not a pretty sight.
Spun mine over by hand a bunch of times. Hope that it's good to go.
Re: Timing sprocket marks [Re: Dart 340] #67285
06/04/08 12:35 PM
06/04/08 12:35 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
nope it is ugly. makes me sick. the car is all done and now it doesn't have a motor. but a redo is in progress.
Dart 340 did u use any clay to check for clearance?
Re: Timing sprocket marks [Re: 65cuda] #67286
06/04/08 12:45 PM
06/04/08 12:45 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
I would puke.....
No I didn't, but I have put a couple hundred miles on the car since I bought it a few at over 5,000 RPM. The guy that built mine used a 5/32 key in the cam way instead of 3/16 and also used a bad conical washer with no loctite so the bolt came loose and I lost fuel pressure. Tore it apart and that's what I found. I just was checking timing and that's what I came up with, marks off, or what appears to be the only marks I can find, were off like half a tooth to a tooth. I put a TDC finder in the no.1 cyl and put the piston at exactly tdc then checked the valves. Preload was good and they appeared to travel correct during rotation so it appears the cam lobe is pretty close to center...
I don't honestly know how to check it any other way.
Re: Timing sprocket marks [Re: Dart 340] #67287
06/04/08 01:21 PM
06/04/08 01:21 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
The problem with the multi-keyway gears is just what is pictured. The marks by the keyway are usually not the ones that are used to line up. There usually an index timing mark. There really won't be a whole bunch of crank and cam position change. a couple of degrees one way or but not a 'few teeth' one way or the other.
Re: Timing sprocket marks [Re: MoparforLife] #67288
06/04/08 01:39 PM
06/04/08 01:39 PM
Dayton, Ohio
65cuda Offline
mopar addict
65cuda  Offline
mopar addict
Dayton, Ohio
that is right. i have had to learn way more about timming sets than i wanted to. it has a -4 and a +4 keyway too but the marks for them. they are almost ivisable too or i would have figured it out . maybe. if you look hard at that pic. you can see a pine needle on the ground it's a good closeup. it's a crazy except for the few with blowers or specal setups. probably 98 % of the people just put them in straght up or dot to dot. Comp Cams web site says they gring them 5 degrees advanced anyway so why advance it more. i know there is a group of builders out there that has a reason. just not us reg. guys. so my finished car sets there waiting for a new heart.
Re: Timing sprocket marks [Re: MoparforLife] #67289
06/04/08 02:12 PM
06/04/08 02:12 PM
Dart 340 Offline OP
moparts member
Dart 340  Offline OP
moparts member
Well I'm hoping since mine ran well before I took it apart it will be fine once I fire it up tonight. I didn't change anything. Maybe next time I have to tear it down I will go through the instructions from Edelbrock and actually degree it.
Re: Timing sprocket marks [Re: Dart 340] #67290
06/04/08 03:34 PM
06/04/08 03:34 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Hate to say this... 65cuda, your issue was installation error. It sucks tht this happened. I've seen this a bunch of times and was pretty common in the 80's when cloyes true rollers were popular. People would bring in a part and the instruction sheet was neatly folded just like the manufacturer had placed it in the box. Never disturbed or read by the installer.
There are marks on the crank gear for lining up with the cam gear. See the circled areas of the picture. I've seen guys put the gear on for 4* advance and then line up the zero mark on the crank gear, so this isn't a rare occurrance.
IMO, you got a good part and it wasn't mancinis fault your issue occurred. Another real good reason to degree in the cam. Had degreeing been done, you'd have caught the issue before the damage was done.
Again, it sucks this happened to you.
