Low gear sets in A904 Torquefilte #672728
04/17/10 05:40 PM
04/17/10 05:40 PM
Spokane Valley, Washington
stryker63 Offline OP
Hello,
In a previous post I asked for opinions on whether I should get a lock-up or non-lockup A904 for my '73 Duster project - thanks to all who responded.
In the meantime, it was suggested to me that instead of getting a late model A999/998 to take advantage of its 2.71 low gear ratio, I should instead rebuild an earlier A904 with the low gear set.
I will be using a mildly built 5.2L Magnum and an 8 1/4" rear end with a 2.45 ratio.
Any thoughts?
Re: Low gear sets in A904 Torquefilte [Re: stryker63] #672729
04/17/10 05:50 PM
04/17/10 05:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The A999 is a stronger unit to start with, more clutches and wider band.
Re: Low gear sets in A904 Torquefilte [Re: stryker63] #672730
04/17/10 08:00 PM
04/17/10 08:00 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
A 904 out of a Cordoba should have a low gear set. Unless you are going to 500+ HP with a trans brake, a 904 will hold up just fine. Just remember to adjust the second gear band after break in(approx 500 miles)
Re: Low gear sets in A904 Torquefilte [Re: babarracuda] #672731
04/17/10 09:36 PM
04/17/10 09:36 PM
What year range on the Cordoba?
Would any late-model A904 work? I would imagine that any tranny from an M, J, or F-body would do the trick...?
