BB composition head gaskets, revisited #672229
04/17/10 12:41 AM
04/17/10 12:41 AM
communist bloc of new jersey
jamesc Offline OP
jamesc  Offline OP
would like to get together a list of composition gaskets with their characteristics and if possible have it archived. for the most part all the different MLS and copper offerings are pretty well identified through the vendors but the composition stuff seems a little more mysterious. feel free to add or correct information, a lot of info is from summit. i "thought" the mopar performance gaskets used to be the 1009 and the detroit but looking at the construction they have no wire and the 1009 does. prices posted are summit list without possible discounts.
fel pro....
8519PT1-basic stock permatorque, no wire, eyebrows, iirc around .041-.044 compressed. good sized bore, will fit bores with large chamfers, good gasket for mild builds. $18 each
17059- this is the marine head gasket, 4.5 bore, no wire, .039 compressed, 10.3cc (stainless construction?) $49 each
1009-race gasket with wire, .039 compressed, 4.41 bore, 9.9cc, often will not work on >4.375 bore. $42 each
1039-race gasket with wire, .051 compressed, 4.59 bore, 13.7cc, clear pretty much any bore or chamber. believe will fit wedge or hemi. $62 each
1095-no wire, steel core laminate, pro stock for the TS head, .051 compressed, 4.62 bore, 15cc $80 each
1105-race gasket with wire, .051 compressed, 4.59 bore, 13.7cc wedge only. $74 each.
mopar performance....
P4349559- race gasket no wire, .040 compressed 4.38 bore, 9.8cc. i thought this was the 1009 but it isn't as it has no wire. $60 pair
P4529455- race, no wire, eyebrows, .038 compressed, 4.42 bore, 9.55cc. $74 pair
victor reinz 3464SG (nitroseal)-performance, .045 compressed, 4.43 bore, 11.1cc. they also have MLS offerings in their performance catalog probably made by another manufacture
victor reinz 3464VC, listed as VR2000 construction. good luck finding any more about this one
detroit gasket(corteco?)-55655HG race, no wire, eyebrows, .038 compressed, 4.42 bore, 9.55cc same as P4529455
ROL HG31130HT- race, eyebrows?, .045 compressed, 4.505 bore, 11.8cc
edelbrock 7325-.038 compressed, 4.45 bore, 9.969cc. $62pair
Re: BB composition head gaskets, revisited [Re: jamesc] #672230
04/17/10 01:28 AM
04/17/10 01:28 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Great post, With all of our different needs here at moparts, this is what we need . mike
Re: BB composition head gaskets, revisited [Re: jamesc] #672231
04/17/10 02:02 AM
04/17/10 02:02 AM
Arizona
Chris'sBarracuda Offline
Arizona
I just got the 1105 Fel Pros for $64.00 @ Summit Pro Shop.. Best deal..
I prefer these.
Chris..
Re: BB composition head gaskets, revisited [Re: Chris'sBarracuda] #672232
04/17/10 06:21 AM
04/17/10 06:21 AM
tboomer Online work
tboomer  Online Work
Re: BB composition head gaskets, revisited [Re: jamesc] #672233
04/17/10 09:27 AM
04/17/10 09:27 AM
NC
440Jim Offline
440Jim  Offline
NC
P4529455- no wire, .038 compressed. 4.42 bore, 9.55cc. $74 pair
victor reinz graphite coated?
detroit gasket-iirc similar to the fel pro 1009 in dimensions. part number was HT something and the gasket was orange. i believe it was also sold by mopar performance.
That is the MP gasket I used on my 451 and 471 CID motors in the past (2002-2004) at ~12 CR). I thought it was the Detroit gasket. On a used one, I measured the gasket dia is about 4.40", plus the added "eyebrows" for the valve areas.
Re: BB composition head gaskets, revisited [Re: 440Jim] #672234
04/17/10 09:39 AM
04/17/10 09:39 AM
NC
440Jim Offline
440Jim  Offline
NC
This is the old package. I have no idea if Mopar Performance is still using the same gasket with this part number.
EDIT: And this is what the MP catalog in 2000 said:
P4529455: B/RB - Up to 4.380" bore
Re: BB composition head gaskets, revisited [Re: 440Jim] #672235
04/17/10 09:48 AM
04/17/10 09:48 AM
jamesc Offline OP
jamesc  Offline OP
great Jim thanks. at this point i'm going to assume that is still the same piece and edit my post. i also add the eyebrow aspect to the gaskets i know have them.
Re: BB composition head gaskets, revisited [Re: jamesc] #672236
04/17/10 09:56 AM
04/17/10 09:56 AM
jamesc Offline OP
jamesc  Offline OP
i'm now looking into this more that gasket might be a corteco
Re: BB composition head gaskets, revisited [Re: jamesc] #672237
04/17/10 10:00 AM
04/17/10 10:00 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
The last MP head gasket that I bought about a year ago, was the Felpo 1009. The biggest problem that I see with those gaskets is the that the fire ring actually stuck out into the cyl bore on a .060" over 440. I tried to use a used 1009 with the honing plate to hone my new .030" over 440, but the hone hit the fire ring on it also.
Brian
Re: BB composition head gaskets, revisited [Re: jamesc] #672238
04/17/10 10:05 AM
04/17/10 10:05 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Great thread, I'd like to add that I checked out the Edelbrock 7325 the other day and it looks just like the orange gasket 440Jim posted but it's white. It has the same little dots all over it. It is a steel core laminate which is suppose to handle decent compression, 12 to 1 or a little higher. Supposedly made by ROL.
.038 thick, 4.450 bore, $62 a pair.
Here they are................
Re: BB composition head gaskets, revisited [Re: '72CudaRacer] #672239
04/17/10 10:15 AM
04/17/10 10:15 AM
jamesc Offline OP
jamesc  Offline OP
Brian, that's the reason for this post. to try to hammer out what will and will not work for different applications. for instance afaik the 8519PT1 will make it on just about any bore that a gasket of it's quality might be used on but it won't hold high CR. probably safe for most (no nitrous) applications up to 11:1ish. bore and chamber overhang is a constant problem. you can solve that by using gaskets like the 1105 but it's a real cc hog and may open up the quench distance more than you want.
Re: BB composition head gaskets, revisited [Re: ProSport] #672240
04/17/10 10:16 AM
04/17/10 10:16 AM
tboomer Online work
tboomer  Online Work
Just got a pair of the eddy ones yesterday...Pro Shop price...53.00...
Re: BB composition head gaskets, revisited [Re: jamesc] #672241
04/17/10 10:18 AM
04/17/10 10:18 AM
jamesc Offline OP
jamesc  Offline OP
also guys i'm not saying any of this is written in stone, this is a work in progress and i'll edit it as we go.
Re: BB composition head gaskets, revisited [Re: jamesc] #672242
04/17/10 10:33 AM
04/17/10 10:33 AM
PA
moparacer Offline
moparacer  Offline
PA
Great info thanks for posting!
I am also stuck using a 1105 with a 4.38 bore and Indy heads.
Kills compression with a 4.59 bore and .051 compressed thickness.
I would gain a half a point compression going with something like that Edelbrock 7325 but I dont know how it would hold up to 13:1 compression..
Any other options?
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: BB composition head gaskets, revisited [Re: moparacer] #672243
04/17/10 10:47 AM
04/17/10 10:47 AM
jamesc Offline OP
jamesc  Offline OP
i don't know to be honest. i'd like to get others opinions on this but i'm thinking anything over 12.5:1 starts pushing the limits of composition gaskets especially ones without wire in them. not that it can't and hasn't been done (often) just that the reliability starts to go down. questions like these are the reason for the post. imho the 1039-1105 are thicker than needs be but maybe this is a manufacturing requirement althought the 1009 isn't that thick but won't fit many bore sizes.
Re: BB composition head gaskets, revisited [Re: moparacer] #672244
04/17/10 10:58 AM
04/17/10 10:58 AM
NC
440Jim Offline
440Jim  Offline
NC
Any other options?
I run Cometic MLS head gaskets in my 13.5 CR motor. Costly, but I have reused them 3 times during engine teardowns, so they paid for themselves compared to throw aways.
Re: BB composition head gaskets, revisited [Re: 440Jim] #672245
04/17/10 11:17 AM
04/17/10 11:17 AM
jamesc Offline OP
jamesc  Offline OP
yea jim for the most part i'm figuring builds at that level are going to be using MLS or copper and these all seem to be pretty well defined. as you said you can usually get some reuse out of them so the actual cost goes down.
Re: BB composition head gaskets, revisited [Re: moparacer] #672246
04/17/10 01:33 PM
04/17/10 01:33 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Any other options?
The 7325 is a stell core laminate, which is suppose to be better than a regular composition gasket. I think you'd be ok honestly. The guy at Summit told me they've been using the steel core laminate gaskets on everything, even turbo cars.
Re: BB composition head gaskets, revisited [Re: ProSport] #672247
04/17/10 07:59 PM
04/17/10 07:59 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Nice list!
Quick correction though:
The ROL HG31130HT are .045 compressed thickness.
Re: BB composition head gaskets, revisited [Re: cl440] #672248
04/17/10 08:13 PM
04/17/10 08:13 PM
jamesc Offline OP
jamesc  Offline OP
OK thanks, i edited the list and hunted down the bore and volume as well
