W5 Intake Manifold #671716
04/16/10 08:06 PM
04/16/10 08:06 PM
British Columbia
plumcrazy101 Offline OP
British Columbia
Would anyone have a photograph of Mopar's W5 intake manifold
part number P5249614.
Re: W5 Intake Manifold [Re: plumcrazy101] #671717
04/16/10 08:29 PM
04/16/10 08:29 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
It's the one on the left.
Re: W5 Intake Manifold [Re: S/ST 3040] #671718
04/16/10 10:49 PM
04/16/10 10:49 PM
British Columbia
British Columbia
Just a follow up question on the manifold, and I hopefully won't be a PITA but would the casting number on the manifold be 4452893?
Re: W5 Intake Manifold [Re: plumcrazy101] #671719
04/16/10 10:58 PM
04/16/10 10:58 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
I have two of the MP M1 intakes with 893 and they are standard LA bolt pattern....not w5
Tony
70 AARCuda Vitamin C
Re: W5 Intake Manifold [Re: plumcrazy101] #671720
04/17/10 10:04 AM
04/17/10 10:04 AM
Minnesota
Coldart Offline
Coldart  Offline
Minnesota
Casting #4452893 is on the right in picture (small runner)
Manifold on left casting #P4532658 (large runner)
Re: W5 Intake Manifold [Re: Coldart] #671721
04/17/10 11:50 AM
04/17/10 11:50 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
just went out in the garage and looked...
the two LA standard head bolt pattern heads have the 893 casting....and the brand new in the box W5 intake has the 893 casting...
so you can not just go my the casting number..the intakes appear identical except for the bolt pattern...
this intake is setting on top of a set of eddy heads...and the standard LA intake gaskets line up.
same casting ...different part numbers...
but the part numbers are not on the intake only the casting...
Tony
Re: W5 Intake Manifold [Re: 70AARcuda] #671722
04/17/10 11:53 AM
04/17/10 11:53 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
this is new in the box w5 intake...same casting number ...
Tony
Re: W5 Intake Manifold [Re: 70AARcuda] #671723
04/17/10 12:12 PM
04/17/10 12:12 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
bottom intake isn w5...wider bolt pattern..other wise they look identical...
would this lead you to believe that you can take a standard LA intake and redrill it ...and it will fit a w5???
Tony
Re: W5 Intake Manifold [Re: 70AARcuda] #671724
04/17/10 12:37 PM
04/17/10 12:37 PM
Earth
Rob C Offline
Rob C  Offline
Earth
Seldom am I here or reply, but I thought this A good idea to and time to post. At risk, here's a bunch of shots on a intake I have for sale at another site, worthy of a look.
It has the wide bolt spacing of the W series heads and the same casting numbers as 70AAR.
It so appears that this intake is drilled as needed, OE heads, W5 heads. The ports are very close to gasket matched. Black marker shows the slight grinding effort needed for a port match.
http://www.forabodiesonly.com/mopar/showthread.php?t=97082
Re: W5 Intake Manifold [Re: 70AARcuda] #671725
04/17/10 07:41 PM
04/17/10 07:41 PM
S/ST 3040 Offline
S/ST 3040  Offline
The W-5 version would also have to be milled for OEM port alignment.
W-5 heads have raised intake (and exhaust) ports.
Re: W5 Intake Manifold [Re: S/ST 3040] #671726
04/17/10 08:09 PM
04/17/10 08:09 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
so if i go set the w5 intake on the eddy heads it should stick up in the air??
going to go try this
w5 intake seem to want to set up somewhat when placed on the standard/eddy heads...
well...end of that story..
Tony
Re: W5 Intake Manifold [Re: 70AARcuda] #671727
04/18/10 11:33 PM
04/18/10 11:33 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I had one of those intakes I bought off the Archer Brothers when Dodge pulled out of Trans-Am (again). It didn't match the ports on the W-5 heads I bought from them. Not really close.
Floyd Lippencott IV
Re: W5 Intake Manifold [Re: 70AARcuda] #671728
04/19/10 09:19 AM
04/19/10 09:19 AM
S/ST 3040 Offline
S/ST 3040  Offline
Remember the W-5/W-7 spacers for the end rails?
