Which Spindles to use??? #671628
04/16/10 05:20 PM
04/16/10 05:20 PM
CentralVA.
BBCoronet Offline OP
CentralVA.
Getting ready to put this together --> 71 Duster 383 /auto - SS springs - 8 3/4 with big bolt pattern and a choice of 73-76 A body disc or F M J body disc brakes. I like the 70s high & mighty looks so would there be a preference in spindles if you're going to crank the torsion bars up. Now let the begin!
Re: Which Spindles to use??? [Re: BBCoronet] #671629
04/16/10 05:38 PM
04/16/10 05:38 PM
BDW Online content
BDW  Online Content
It's an A-body, so why not use the A-body spindles?
Re: Which Spindles to use??? [Re: BDW] #671630
04/16/10 05:58 PM
04/16/10 05:58 PM
CentralVA.
CentralVA.
Well my question was if there would be a preference - Tall or Short when going big block and raising the front end up higher than normal via the torsion bars........
Re: Which Spindles to use??? [Re: BBCoronet] #671631
04/16/10 05:59 PM
04/16/10 05:59 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
No real difference in ride height. I would use the "A" body spindles in your case.
Re: Which Spindles to use??? [Re: 5spdcuda] #671632
04/17/10 03:58 AM
04/17/10 03:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
There has been alot of debate and crosstalk about the pluses and minuses with each knuckle. The B, FMJR body knuckle has one advantage over the A knuckle, but I have read that it only pertains to Camber Curve at or near full suspension compression. Since you plan to go High boy style, any minor advantage the other knuckle may have, the best choice for you would be the standard A knuckle.
Re: Which Spindles to use??? [Re: Kern Dog] #671633
04/17/10 07:20 PM
04/17/10 07:20 PM
CentralVA.
CentralVA.
Thanks guys....I just bought a 74 A body spool mount K frame and it has the disc brake setup already, so I guess A body it is........
