75 amp Alternator #671170
04/15/10 10:36 PM
04/15/10 10:36 PM
Auburn Hills, Michigan
K
kieron_kohlmann Offline OP
K
so i have a 50 amp alternator and it doesnt have enough juice to keep up. i cant seem to find a 75 amp. alternator that isnt chrome. any one have some ideas?
Re: 75 amp Alternator [Re: kieron_kohlmann] #671171
04/15/10 10:42 PM
04/15/10 10:42 PM
gtx69 Offline
super gas
gtx69  Offline
super gas
Check with www.manciniracing.com.They have a 75 amp that's not chrome by powermaster
Re: 75 amp Alternator [Re: gtx69] #671172
04/15/10 10:46 PM
04/15/10 10:46 PM
IN
ahy Offline
ahy  Offline
IN
Bouchillon used to sell one also.
Re: 75 amp Alternator [Re: kieron_kohlmann] #671173
04/16/10 02:05 AM
04/16/10 02:05 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
simply stock lates 70s alts...
PNs Beck/Arnley 186-6002, dual pulley but can be changed...
http://c2c.activant.com/ctoc/index.jsp?ID=gGA1KJhwDA0dBFR0MaSREf2RHG1R.AxgIX3dOTwEEXxkA
available at Clearly Auto on $32.78 plus $15 core
http://www.clearlyauto.com/catalog/1974/...tors-Generators
it is dual field... if you have single field setup, simply ground one of the brushes
it is A LITTLE BIT WIDER than roundbacks and earliers squarebacks due the wider windings at stator, so will fit TIGHT ( rear spacer can be milled down a liitle bit too ). recomended use a little bit longer belt to keep away the back of alt from block.
more reading about same alt installation:
http://www.moparmusclemagazine.com/techa...ator/index.html
IMPORTANT... UPGRADE MAIN CHARGE WIRES:
http://www.dodgecharger.com/forum/index.php/topic,33574.0.html
more readings about ( including the one above ) here:
http://www.dodgecharger.com/forum/index.php/topic,62772.0.html
Re: 75 amp Alternator [Re: kieron_kohlmann] #671174
04/16/10 09:41 AM
04/16/10 09:41 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
You can also rebuild your own alternator. The only appearance issue is that it will be slightly thicker.
http://store.alternatorparts.com/daimlerchrysler.aspx
One caution: Your bulkehead connector is not rated to handle that much current. Use the factory manual to convert to police/taxi wiring for 55Amps and above. It is in the Satellite and Fury wiring diagrams for Plymouth, Coronet, Diplomat diagrams for Dodge.
Craig
Re: 75 amp Alternator [Re: kieron_kohlmann] #671175
04/16/10 10:18 AM
04/16/10 10:18 AM
Andrewh Online content
Andrewh  Online Content
I agree, order the 89 new yorker alternator for the full size.
It will be around 75 amps.
For the sb, I found, I could not get the swing arm to line up. The alt went out too far.
The chrome gm swing arm, (10 bucks new) reached out far enough, but I needed a spacer on the block to line it up.
Re: 75 amp Alternator [Re: Andrewh] #671176
04/16/10 10:29 AM
04/16/10 10:29 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Powermaster also makes a 100 amp alternator that is the same sqaureback style as our older type.
Re: 75 amp Alternator [Re: denfireguy] #671177
04/16/10 11:53 AM
04/16/10 11:53 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
Wow i never knew that existed. I might have to try one of those kits out.
Re: 75 amp Alternator [Re: RacerGofKGB] #671178
04/16/10 03:15 PM
04/16/10 03:15 PM
BDW Online content
BDW  Online Content
I was looking at RockAuto and they list alternators from 50-100A, give them a look.
Re: 75 amp Alternator [Re: BDW] #671179
04/16/10 08:15 PM
04/16/10 08:15 PM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
To the best of my knowledge, the 100A versions require a completely different mounting scheme.
Re: 75 amp Alternator [Re: Pat_Whalen] #671180
04/16/10 11:36 PM
04/16/10 11:36 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
