oil&additive for breaking in the cam? #670600
04/15/10 02:20 PM
04/15/10 02:20 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
A friend is freshening up the 289 for his '65 mustang and bought a new isky solid lifter cam.I told him about most people using deisel oil and the comp additive but he said the paperwork with the cam recommended racing oil and not to use the deisel oil since most companies are reducing the zinc in the deisel oil.
What are you guys having good luck with now?
Re: oil&additive for breaking in the cam? [Re: 70SWGR] #670601
04/15/10 02:25 PM
04/15/10 02:25 PM
NC
Badfish67 Offline
Badfish67  Offline
NC
I use Brad Penn 30wt break in oil with the Comp Cams Break-In lube too. Maybe a little overboard with the break in lube but I would rather be safe than sorry...
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: oil&additive for breaking in the cam? [Re: Badfish67] #670602
04/15/10 02:26 PM
04/15/10 02:26 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
That was the no.1 oil isky recommended.
Re: oil&additive for breaking in the cam? [Re: 70SWGR] #670603
04/16/10 02:10 AM
04/16/10 02:10 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I think that following the cam manufacturers recommendations would be a good idea. Okay, now that the weekend is coming, they surely won't answer the phone. The local auto parts store has a few decent choices. I use Valvoline VR Max. It has higher zinc than standard oils and costs about $ 4.00 per QT. Z Alt has been advertised in the Mopar mags. I also use the Comp Cams break in lube during cam break in and at every oil change as cheap insurance. I dont drive my hot rods but 1500 miles per year, unlike my 40,000 mile per year '07 Ram truck.
Re: oil&additive for breaking in the cam? [Re: Kern Dog] #670604
04/16/10 03:39 PM
04/16/10 03:39 PM
fury4speed Offline
fury4speed  Offline
Second the BradPenn , no oil on the Auto Parts shelf has more Good stff in the Oil than BradPenn.
http://www.bradpennracing.com/
http://www.bradpennracing.com/Products/High-Performance/Break-In-Oil.aspx
Re: oil&additive for breaking in the cam? [Re: fury4speed] #670605
04/16/10 08:05 PM
04/16/10 08:05 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Trick Flow engine oil supplement works well after it has already been broke in
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
