Rotella T 15/40 to Rotella 5/40 Synthetic #670511
04/15/10 01:45 PM
04/15/10 01:45 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
Just did my yearly oil change my 69 coronet; Went from Rotella T 15/40 to Rotella 5/40 Synthetic...
Oil pressure still on the high side, 80lbs cold idle, 45 hot idle after 20 mins and a couple of high rpm highway runs, temp at 170, outside at 60ish.
Any thoughts on this oil? Was looking for slightly lower oil pressure on fire up, not finding it.
Any additional additives needed for flat tappet 550" lift cam?
Thanks for all input.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Rotella T 15/40 to Rotella 5/40 Synthetic [Re: Hoof Hearted] #670512
04/15/10 09:49 PM
04/15/10 09:49 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I was running the Rotella 15W-40 but switched later to GTX 20W-50. I have a .509 cam and usually throw in a bottle of the Comp Cams break in lube. However, I bought a bottle of Lucas Zinc additive the other day at Napa for $12. I only change my oil once or twice a year because i don't drive the car much so I don't mind spending $12 on a zinc additive.
BTW, this is in a decently built 440. I have about 70lbs @ startup and around 50lbs @ hot idle. Not sure if I answered anything but hope it helps you in some way.
Re: Rotella T 15/40 to Rotella 5/40 Synthetic [Re: JoesMopar] #670513
04/15/10 09:58 PM
04/15/10 09:58 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I have run Rotella, I went with Valvoline 20/50 VR1 just the other day, 70psi on startup warms up drops to 40psi then will go between 50-70psi depending on how much your foot is in it. The Rotella got black in my car after a summer. I think it was probably a tunning issue and not the oil. I run it in my truck and I cant make it black in 4k miles.
Re: Rotella T 15/40 to Rotella 5/40 Synthetic [Re: Joshs68] #670514
04/15/10 10:44 PM
04/15/10 10:44 PM
IN
ahy Offline
ahy  Offline
IN
I wouldn't worry too much about 80 PSI cold idle unless it goes over 100 when you rev it. Hot pressures sound fine.
The Rotella is probably fine at spring pressures used for .55 lift. I run Rotella plus STP for a little extra zinc and insurance though.
