MSD 7531 BOX...COIL ????? #669909
04/14/10 08:51 PM
04/14/10 08:51 PM
Ontario, Canada
mrplymouth Offline OP
Ontario, Canada
Hey all, I have a brand new MSD 7531 Digital box, I am going to install it, and was wondering, can I use a MSD 8207 Coil....it says MSD Blaster SS on it ??? Or "MUST" we use an 8251 ??? Only reason I suggest the 8251 is it will see a little bit of street use.....8207 says its good for 40,000 volts .....8251 says its good for 45,000 volts ???????? HELP !!!
Re: MSD 7531 BOX...COIL ????? [Re: mrplymouth] #669910
04/14/10 11:13 PM
04/14/10 11:13 PM
Columbus, OH
Ben Holt Offline
Ben Holt  Offline
Columbus, OH
The only coil I recommend for the -31 box is the 8261 HVC II coil. As long as you don't dirve the thing for a couple hundred miles at a time it will be fine
Re: MSD 7531 BOX...COIL ????? [Re: mrplymouth] #669911
04/14/10 11:18 PM
04/14/10 11:18 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
MSD recdommends the 8251, 8252, and the 8261. The 8207 looks to be for the 6 series box and may not function properly with a 7 digital. The 8252 comes up as for the 6-box as well, so I couldn't tell you for sure. You might try checking with their tech dept. online or by phone. They have always been very helpful for me.
FYI - the 7531 box is NOT allowed for NHRA competition. The "slew rate" function could be used as traction control which is banned.
Re: MSD 7531 BOX...COIL ????? [Re: mrplymouth] #669912
04/14/10 11:39 PM
04/14/10 11:39 PM
The Wet Coast, Canada
megajoltman Offline
megajoltman  Offline
Not according to MSD's coil compatibility list
http://www.msdignition.com/products/coils/
1969 Dart 383/727/D60
CTD Ram 4x4 Mega Cab
Procharged 350Z
