Brake swap? #669400
04/14/10 12:20 AM
04/14/10 12:20 AM
Iowa
76dodgeboy Offline OP
Iowa
I have a 8 3/4 that needs all the brakes and I have a 8 1/4 and 9 1/4 that are complete. Can I swap the brakes fron either to the 8 3/4? Thanks
Re: Brake swap? [Re: 76dodgeboy] #669401
04/14/10 01:15 AM
04/14/10 01:15 AM
only if you have BBP axles in the A body 8&3/4 which were cut down to the regular BBP brake offset distance when they were machined (which most are so as to use std 10" BBP brakes which the 8&1/4/9&1/4 would have).
Re: Brake swap? [Re: 76dodgeboy] #669402
04/14/10 02:18 AM
04/14/10 02:18 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
ALL 8.25 and most 9.25 backing plates/Brake assemblies will interchange, assuming they are passenger car axles. The light duty 3/4 ton truck 9.25 had 8 lug rims with totally different backing plates and drums. ALSO, consider post 73 A body cars with disc brakes. Even the 7.25 axle cars used the same backing plates as the 8.25 and 9.25 axle.
Re: Brake swap? [Re: Kern Dog] #669403
04/14/10 09:34 AM
04/14/10 09:34 AM
For some reason I got to thinking you were referring to an A body 8&3/4. My bad
Re: Brake swap? [Re: RapidRobert] #669404
04/14/10 01:18 PM
04/14/10 01:18 PM
Iowa
Iowa
No A-body here. Cant afford one. Its going in a truck. Thanks for the info. Now I will have brakes for a couple 8 3/4s
