Re: trying to figure out what happened to my piston rings..
[Re: CokeBottleKid]
#669241
04/13/10 09:44 PM
04/13/10 09:44 PM
the 2.76 gears DID NOT cause that.....
[Re: dirtybee]
#669243
04/13/10 09:47 PM
04/13/10 09:47 PM
Posts: 43,308 Bend,OR USA
Cab_Burge
I have never seen piston rings break into so many pieces ![](/ubbthreads/images/graemlins/shock.gif) Can you take a good close up picture of one of the piston tops (broken ring one) from the side so we can see the side of the piston above the top ring? Oil will and does cause detonation ![](/ubbthreads/images/graemlins/tsk.gif) What do the sprak plugs look like? Picture also ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: dirtybee]
#669246
04/13/10 10:09 PM
04/13/10 10:09 PM
Posts: 74 virginia
tigger1
virginia
I have seen top rings do this once before with to much clearance/too thin of a ring...don't ask how I found out...
Twin turbo 440 72 barracuda
[Re: dirtybee]
#669252
04/13/10 10:51 PM
04/13/10 10:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I sure dont see any signs of a problem in the piston pics... doesnt even look like detonation from the top edges but I'm not saying it wasnt that... I have seen rings break but not like yours... just 1 break so it has 2 parts.... and you say you have 7 pistons that did that ![](/ubbthreads/images/graemlins/wave.gif)
[Re: MR_P_BODY]
#669253
04/13/10 11:00 PM
04/13/10 11:00 PM
Posts: 807 Toronto, Canada
dirtybee
Toronto, Canada
I sure dont see any signs of a problem in the piston pics... doesnt even look like detonation from the top edges but I'm not saying it wasnt that... I have seen rings break but not like yours... just 1 break so it has 2 parts.... and you say you have 7 pistons that did that ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
i know....what the heck? what about running low on oil? i figured the two were seperate problems but????
[Re: dirtybee]
#669254
04/13/10 11:02 PM
04/13/10 11:02 PM
Posts: 294 Minnesota
RockChip
Minnesota
Sweet Sweet Detonation. ![](/ubbthreads/images/graemlins/maad.gif) What does the top of your intake valves look like? I bet that the plug that poped out of your rocker shaft filled the head enough to have the oil level above the valve guides, and if thare worn and all you have is umbrella seals that the extra oil caused detonation and broke the rings. This time maybe some better rings and maybe a overbore. ![](/ubbthreads/images/graemlins/thumbs.gif) Also some guide liners and some positive seals should do the trick. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: dirtybee]
#669257
04/13/10 11:49 PM
04/13/10 11:49 PM
Posts: 1,093 Long Beach, CA
Mike Swann
Long Beach, CA
I had that happen one time with one piston. My wife was nagging me while I was assembling the engine, and I accidently reversed the top and second ring.
The cast scraper shattered exactly like that. You may have a set of 2 scrapers due to mismarking also.
8.30's @3400 lbs
