Re: Has anyone used the Hotchkis geometry-corrected A arms?
[Re: JF_Moparts]
#668787
04/13/10 01:06 PM
04/13/10 01:06 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I have them and for the most part like them. Get the tie rod bump steer kit and the get their shocks instead of the KYBs or buy mine so I can get the Hotchkis shocks.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: JF_Moparts]
#668788
04/13/10 07:20 PM
04/13/10 07:20 PM
Posts: 203 Sante Fe Springs, CA
Hotchkis
We'd recommend swapping out the KYBs for a more high performance shock like Bilstein. The cheaper shocks just don't perform well and for a few more dollars a performance shock will provide considerably better service for years to come. Definitely one of those "you get what you pay for" situations - even if you don't use ours. As far as your tracking and bumpsteer issues go, a combination of tubular control arms (for extra caster) and our adjustable tie rods will dramatically reduce bumpsteer and improve tracking. Each car is different, but we can offer recommendations on spacer settings for the tie rods. A third thing is to find an alignment shop that can actually work on your car. Most modern shops really don't do a very good job of aligning vintage muscle cars. Stock Challenger Before and After
[Re: Hotchkis]
#668789
04/13/10 08:56 PM
04/13/10 08:56 PM
Posts: 1,164 Los Angeles, CA
JF_Moparts
Los Angeles, CA
I forgot to mention that I already have tubular upper A arms in the car, but not the ones you offer. If the corrected geometry arms make a big difference, then they're worth it to me.
I currently run the C-body tie rods.
I have a good shop for alignment - Bagge & Sons in Culver City, recommended to me by autoxcuda of CPW fame.
What would help me the most, quite honestly, is for someone who knows their stuff to ride or drive my car and make recommendations. I actually called Hotchkis last week and asked if that service was available, or if you'd be hosting any performance clinics. I was transfered to a voice mail and left a message, but have not heard back yet.
I'm not afraid to spend the money, but I need some insight into the value/improvement I'll be getting from the product. I don't like shooting in the dark.
[Re: HealthServices]
#668791
04/13/10 10:06 PM
04/13/10 10:06 PM
JF_Moparts
Los Angeles, CA
Do they lower the point where they attach to the control arm? Are they ajustable to your ride height? The tie rod ends that Hotchis sells is not to beef up the tie rod ends. They are there to correct the bumpsteer.
Doing this maybe a worth while upgrade, esp if your concern is bumpsteer.
Well, yeah, they don't do any of that. I was just adding what I forgot to put in my opening post.
I want to get my car to ride and handle the best it possibly can, within reason. I just want to see some kind of cost/benefit beforehand.
#668793
04/13/10 11:30 PM
04/13/10 11:30 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Although I picked mine up, they were packed very well.
Allen
#668794
04/13/10 11:35 PM
04/13/10 11:35 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I ended up doing my own alignment. I just dropped a plumb bob from the lower ball joint, Chalked up 20 degrees...
I'm sure the actual pivot point is a inch or so out from this point depending on the the location of the upper ball joint but this will give me a estimate and good starting point.
Allen
[Re: JF_Moparts]
#668798
04/14/10 12:08 AM
04/14/10 12:08 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
I think that is a good idea. I bet your issue or more non bump steer related. Like shocks.
I think you could get the Hotchkis shocks for around $400 for 4. Not hard to install yourself, and you wouldn't need to re-align the car or pay labor to install the uppers.
Maybe bring your car out to Spring Fling and maybe after 1pm when the midway activity dies down some someone there could could drive it? Just a suggestion.
You can drive mine after 2pm or so. But I don't have any Hotchkis stuff on my car though.
[Re: autoxcuda]
#668799
04/14/10 12:54 AM
04/14/10 12:54 AM
JF_Moparts
Los Angeles, CA
Hmmm, possibly. This year I'll be bringing my Road Runner to the Spring Fling, but maybe I can bring the RR on Saturday and the Satellite on Sunday, assuming someone is there to assess the Satellite.
[Re: JF_Moparts]
#668801
04/14/10 01:46 AM
04/14/10 01:46 AM
autoxcuda
So Cal
Maybe talk to the Hotchkis guys on Saturday and see if you could set a time or something up for Sunday.
Yeah, assuming you can locate him, he'll be running around like a crazy person all weekend!
This is true. But by 1-2pm on Saturday I've calmed down a bit.
