Vented vs. Non-Vented Gas Tank - E-Body?
#66857
06/02/08 07:09 PM
06/02/08 07:09 PM
Hello, I am curious as to the difference (and reason) for a vented gas tank? I believe I have the "non-vented" type (will attach photo).
Is there any advantage of one over the other? What does a vented-tank look like in the trunk area?
Thanks!!
Re: Vented vs. Non-Vented Gas Tank - E-Body?
#66858
06/02/08 10:59 PM
06/02/08 10:59 PM
Hmm..after seeing your pic, I would think twice about firing up a stogie in your car.
The vented tanks basically have a vent line from gas tank to charcoal canister in the engine bay. Then a line goes to the carburetor..free gas vapors for your carb, at no extra cost to you !
[Re: Alaskan_TA]
#66861
06/02/08 11:55 PM
06/02/08 11:55 PM
Hi,
This is a 1970 Challenger - 440-4bbl Car. It was built in Los Angeles (per Fender tag) and has always been in California (as far as I know).
So, does this sound/look like a "Vented" car? I'm curious because I'm in the market for a new Gas Cap -- and the selections seem to be between Vented and Non. (also, it has the Flip-Top on the outside).
Thanks a lot!
#66862
06/03/08 08:34 PM
06/03/08 08:34 PM
Posts: 4,879 Florida
BDW
Thanks!!
What is that extra tube running up from the trunk floor?
#66867
06/04/08 02:57 AM
06/04/08 02:57 AM
Still...I will not smoke a stogie in that california required system.
Vent the vapors to the trunk it looks like.
Whoever made those laws probably got fired (no pun intended).
