gauge silliness #665333
04/09/10 04:18 PM
04/09/10 04:18 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Okay, interesting problem in the 71 Demon. I have five Auto Meter gauges in my panel - voltage, oil press, fuel level, speedo, water temp. No problems with water temp, speedo, fuel level. But some interesting silliness with the oil pressure and voltage.
You see, everything works out beautifully when the car starts and runs. All gauges show correct. But when I pull the light switch to either parking lamps or headlights, my oil pressure and voltage cease to work. Oil pressure buries itself past 100 and my voltage zeros out. No instrument lamps go on in these gauges either. Additionally, the dimmer switch on the light switch can be used to change the values of these gauges. At this point you're probably saying, "haha, this problem's easy! You have it on the instrument lamp circuit!"
But that's where I can't figure this out. You see, my instrument lamps and my +12V leads to the gauges are on completely different circuits. Further, and here's the kicker, all the instrument lamps are in parallel with each other, as well as the +12V leads on a separate wire(see photo 1).
So you'd assume that if two were having problems, the other three would be, too, because they get their power from the same place.
So I decided to trace it - maybe I wired it wrong somewhere? I traced it back, and all of my +12V are going to the Dark Blue with tracer wire (DB* on the chart in photo 2).
So not sure what's going on. Maybe a bad ground? Maybe something else. Any ideas as to how to test this?
Re: gauge silliness [Re: sharpie] #665334
04/09/10 04:19 PM
04/09/10 04:19 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
Sounds like a ground issue.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: gauge silliness [Re: HealthServices] #665335
04/09/10 04:23 PM
04/09/10 04:23 PM
So Cal
So Cal
How are the headlights grounded?
Headlight switch?
The engine block has a good ground to the firewall?
How about the instruments?
Re: gauge silliness [Re: HealthServices] #665336
04/09/10 04:27 PM
04/09/10 04:27 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Dunno
Headlight switch?
Dunno
The engine block has a ground to the firewall?
The block has a ground to the battery (-)
The instruments ground through an extra opening in the bulkhead connector and attach to a wiper motor nut/stud. My bulkhead connector may be bad, as could be the grounding point on the wiper motor, I suppose.
But why wouldn't they all have issues then?
Re: gauge silliness [Re: sharpie] #665337
04/09/10 04:34 PM
04/09/10 04:34 PM
So Cal
So Cal
As soon as you pull the headlights on if it has a bad ground, it will look for any ground it can get. this includes the instruments.
Remember your oil guage and your voltage guage uses a ground. I'm thinking your headlights is stealing this to complete it's circuit.
Assuming it is doing this I would think your headlights are not the brightest either when it is on.
Re: gauge silliness [Re: HealthServices] #665338
04/09/10 04:35 PM
04/09/10 04:35 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
So you think the headlights have a bad ground, as opposed to the instruments?
Re: gauge silliness [Re: sharpie] #665339
04/09/10 04:37 PM
04/09/10 04:37 PM
So Cal
So Cal
Very bad, put another ground from the block to the chasis and another from the battery to the chasis
Re: gauge silliness [Re: HealthServices] #665340
04/09/10 04:38 PM
04/09/10 04:38 PM
So Cal
So Cal
Is this your only ground for the wiring system? How does it get back to the [-] battery?
You should also have another ground from the wire harness to the core support, but you still need a wire from the battery [-] to all of this...
I mean how does your system get ground if there is nothing going back directly to the battery? You have power going to everything but you don't have ground going to everything.
Re: gauge silliness [Re: HealthServices] #665341
04/09/10 04:45 PM
04/09/10 04:45 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Good question. I am not sure. I guess it grounds to chassis then chassis to engine then engine to battery?
Re: gauge silliness [Re: sharpie] #665342
04/09/10 04:48 PM
04/09/10 04:48 PM
So Cal
So Cal
Yes
How?
Yes, yes, and yes.
You can help it by installing a ground from the chassis to the battery [-]
For the gauges to work properly you need a good ground from the chassis to the engine.
This would be a good start.
Re: gauge silliness [Re: HealthServices] #665343
04/09/10 04:52 PM
04/09/10 04:52 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
How are you grounding the gauge lights?
Re: gauge silliness [Re: stumpy] #665344
04/09/10 04:56 PM
04/09/10 04:56 PM
So Cal
So Cal
Yes I should not assume he did that either.
Re: gauge silliness [Re: HealthServices] #665345
04/09/10 05:02 PM
04/09/10 05:02 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
there's actually two separate grounds for the gauge panel. One is for all of the lights including the signals and hi-beam lights, the other is for all of the gauges. Each runs through the bulkhead and out to the chassis ground inside the engine bay on the wiper motor.
Re: gauge silliness [Re: sharpie] #665346
04/09/10 05:05 PM
04/09/10 05:05 PM
So Cal
So Cal
So there is a ground from the battery to the chassis? Or how is the ground getting back to the battery [-]?
Hopefully not thru the motor mounts.
Re: gauge silliness [Re: HealthServices] #665347
04/09/10 05:08 PM
04/09/10 05:08 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Through the engine itself, I would think. Let me doublecheck my photos though.
Re: gauge silliness [Re: sharpie] #665348
04/09/10 05:11 PM
04/09/10 05:11 PM
So Cal
So Cal
Hopefully not thru the motor mounts but thru a engine ground from the engine to the chassis.
Re: gauge silliness [Re: HealthServices] #665349
04/09/10 05:12 PM
04/09/10 05:12 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
why is that bad? the bolt touches each side, no?
Re: gauge silliness [Re: sharpie] #665350
04/09/10 05:17 PM
04/09/10 05:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Motor mounts are rubber and don't ground to the frame. You diffenately need a ground from the block to the body and to the frame. I have seen more than one throttle cable or shift cable burnt through because they became the only grounds to the engine and couldn't carry the amps from the starter draw etc.
Re: gauge silliness [Re: sharpie] #665351
04/09/10 05:23 PM
04/09/10 05:23 PM
So Cal
So Cal
Not nearly enough. make sure you have both
and
a battery ground from the battery [-] to the chassis.
You also have to have the engine ground but you already mentioned you have a battery [-] to the engine. Which is not enough by itself.
Re: gauge silliness [Re: stumpy] #665352
04/09/10 05:33 PM
04/09/10 05:33 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
What I don't understand here is the car runs fine, charges fine, and even has voltage to spare. It's just the gauges.
