transmission saftey question #665221
04/09/10 01:34 PM
04/09/10 01:34 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
In the process of rebuilting my 904. Was thinking of going with a blanket or shield but really dont want to hassle with them so thinking of another route. I plan to take a 1/8 thick plate round it to fit the main body of the trans and weld it solid to it. My question is how much if any protection with this add? Thanks in advance.
Re: transmission saftey question [Re: E85-408] #665222
04/09/10 01:41 PM
04/09/10 01:41 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
if you're talking 1/8 steel (i assume) probably more protection than either the blanket or shield if done properly but that doesn't mean it will pass tech because the powers that be want their money
Re: transmission saftey question [Re: E85-408] #665223
04/09/10 01:49 PM
04/09/10 01:49 PM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
I've always wondered about some type of kevlar or "flack jacket" type of material that could be glued or attached to the floor board. It would be out ot the way for tranny service/work & should not affect the heat build up many racers have reported.
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: transmission saftey question [Re: jamesc] #665224
04/09/10 01:53 PM
04/09/10 01:53 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
no 1/8 aluminum welded to the trans case. Wanted something Ill never have to mess with or fight with. Im not fast enough to require a blanket/shield just doing it for personal safety and I just have issues with leaving well enough alone.
Re: transmission saftey question [Re: E85-408] #665225
04/09/10 02:16 PM
04/09/10 02:16 PM
Sterling Hts, MI
2
2FASTCORONET Offline
Sterling Hts, MI
Put a blanket on it! When my trans blew, parts went through the floor , there was no case to the tailshaft. I'm a firm beleiver now dennis
Re: transmission saftey question [Re: rockerbob] #665226
04/09/10 03:10 PM
04/09/10 03:10 PM
Seaford Delaware
JSR1485 Offline
JSR1485  Offline
Seaford Delaware
That's what I have in my new ride a scatter blanket from a Nascar team, has heat proof material that goes against the floor and is made out of kevlar-plus a Blanket around the trans. It had snaps that holds it to the floor.
Switched to the dark side...
Re: transmission saftey question [Re: JSR1485] #665227
04/09/10 03:50 PM
04/09/10 03:50 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Keep in mind he's asking about a 904 guys.
I have NEVER heard of a 904 blowing up.
The drum is just too small, it just doesn't have enough rotational inertia to blow itself apart like a 727.
Re: transmission saftey question [Re: dizuster] #665228
04/09/10 04:10 PM
04/09/10 04:10 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
ditto
Tony
70 AARCuda Vitamin C
