Re: Firm Feel or Manual steering
[Re: dd340]
#664572
04/08/10 07:16 PM
04/08/10 07:16 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I'm thinking of installing a steering quickener myself. I don't care for the over assist the factory has and I don't like manual steering either. The steering quickener will reduce the amount of assist to you as well as reduce the amount of turns lock to lock.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#664573
04/08/10 07:21 PM
04/08/10 07:21 PM
Posts: 21,837 Kirkland, Washington
Pacnorthcuda
I was hoping a fast ratio arm would have the desired side-effect of firming up the steering on my PS 'Cuda but the effect on the assist was negligible. Maybe a little. Still over assisted. I swear E-booger had a simple shadetree mod to the box to lessen assist but I don't remember the specifics.
[Re: dd340]
#664577
04/09/10 12:14 AM
04/09/10 12:14 AM
Posts: 7,759 So Cal
HealthServices
So Cal
Hotchkis has it on their E body and it works really well according to them. But I don't think we are suppose to know about this product since they do not sell it. I spoke to tech about it when they had open house once and he showed me it. Short of going to a rack and pinion, this is it. Every time I ask about it on the forum, they act like they have me on ‘ignore’ You have to cut the steering column and this is spliced into it, and reduces the amount of turns either 1.5 to 1 or 2.0 to 1 depending on which one you buy.
Allen
[Re: dd340]
#664579
04/09/10 06:34 AM
04/09/10 06:34 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
For my last two restorations I have rebuilt the steering box to firm feel in both PS systems. One was an a-body the other a b-body and I liked it a lot in both.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: BergmanAutoCraft]
#664583
09/06/10 01:35 AM
09/06/10 01:35 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Not sure where this thread is headed. The ratio multipler box of 1.5 or 2.0 would in IMO make a power steering box WAY too fast, and on a manual box it would likely be WAY too hard to steer/turn under 30mph? without arms the size of the Roc (Not knowing front end weight/tire size makes that a guess). Additionally I can't believe the quickner box is really robust enough for daily driving/parking on a full size street car. IMO, Firm Feel stage 3
[Re: jcc]
#664584
09/06/10 02:01 AM
09/06/10 02:01 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
I thought so too. But everyone that has driven that Hotchkis Emax Challenger loves it.
For some reason I having trouble with the math... 1.5:1 reduction on a 16:1 steering box is what resulting ratio??
10.667 or 12:1 or something else?
.. Additionally I can't believe the quickner box is really robust enough for daily driving/parking on a full size street car...
Circle track cars take a bunch of abuse. The toughness on a deal like that are the impacts on the gears. Like from potholes, curbs, etc. Well, on a circle track car they hit/brush walls at 90-100 mph.
The stock steering column bearings on our cars are nothing too HD or special. I think most of the load are at the box.
[Re: autoxcuda]
#664585
09/06/10 02:04 AM
09/06/10 02:04 AM
autoxcuda
So Cal
The problem with this quickner is that is requires quite a bit of fabrication and time. And it requires a core column. I talked with the guy who made it.
Here's some better pictures.
[Re: autoxcuda]
#664586
09/06/10 02:07 AM
09/06/10 02:07 AM
autoxcuda
So Cal
[Re: jcc]
#664589
09/06/10 11:30 AM
09/06/10 11:30 AM
autoxcuda
So Cal
I suspect the ratio is likely speed dependant, ie slow speeds a slow ratio, med speeds a fast ratio, and ala superspeedway/nascar speeds, they go back to a slow ratio to likely make more precise steering corrections and prevent oversteering, is my guess.
No, those multipliers are just straight gear reduction boxes. Nothing fancy with variable ratios.
On a 1.5:1 multiplier the input makes 1 revolution the output make 1.5 revolutions. Ok, thinking this word problem though...
So 2.0 turns of the steering wheel then into a 1.5:1 reducer box yields 3.0 turns of the steering shaft into the steering box.
Stock 16:1 power steering cars are 3.6 turns lock to lock.
So .4 turns at the steering wheel into a 1.5:1 reducer box yields .6 turns of the steering shaft into the steering box....
So additively, using a 1.5:1 gear reducer in line with the steering shaft with a 16:1 power steering box will give you 2.4 turns lock to lock at the steering wheel and yeilds 3.6 turns into the steering box.
I think the T/A fast ratio is 2.7 turns lock to lock.
I think I answered my own question.
