Did I put my brakes together backwards? #664412
04/08/10 01:10 PM
04/08/10 01:10 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I'm embarassed to ask this now but here it goes - I just finished putting my front suspension back together and I go to put the rubber brake hoses on (factory front discs on a 70RR) and I notice that I would have to stretch the heck out of the hose to get it to run from caliper to frame.
I mounted the calipers on the backside of rotor if viewing from the side...did I screw up and the caliper should be mounted on front side of rotor?
What really makes me stupid is I have a FSM and I thought I had things oriented the way the pictures showed!
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664413
04/08/10 01:22 PM
04/08/10 01:22 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I'm thinking so... Don't feel bad, your not the first one to do it. Which way are the bleeders facing?
Re: Did I put my brakes together backwards? [Re: Challenger 1] #664414
04/08/10 01:26 PM
04/08/10 01:26 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Calipers mount to the front, like Challenger1 said your not the first & won't be the last...
Re: Did I put my brakes together backwards? [Re: Challenger 1] #664415
04/08/10 01:27 PM
04/08/10 01:27 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
There should be something here that helps, plus it's great entertainment!
http://www.sandysgarage.com/current.html
Re: Did I put my brakes together backwards? [Re: Challenger 1] #664416
04/08/10 01:36 PM
04/08/10 01:36 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I was afraid of that! Well I guess I start all over on Saturday, at least I learned something.
Thanks guys!
Re: Did I put my brakes together backwards? [Re: Challenger 1] #664417
04/08/10 01:38 PM
04/08/10 01:38 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Challenger - the bleeders are facing up which I beleive is o.k., right?
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664418
04/08/10 01:39 PM
04/08/10 01:39 PM
NY usa
540challenger Offline
NY usa
Thanks guys!
There is an old saying that we use at work for stuff like this.
"We do it nice because we do it twice"
Re: Did I put my brakes together backwards? [Re: 540challenger] #664419
04/08/10 01:41 PM
04/08/10 01:41 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
just get longer hoses?
Re: Did I put my brakes together backwards? [Re: 05dakota] #664420
04/08/10 01:42 PM
04/08/10 01:42 PM
NY usa
NY usa
THe bigger problem is if the bleeder screw is on the bottom.
Re: Did I put my brakes together backwards? [Re: 540challenger] #664421
04/08/10 03:22 PM
04/08/10 03:22 PM
scratchnfotraction Offline
I have done it on 73+ A-bodys a couple times
longer hose should hook it up
bleeders up top to get air out
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664422
04/08/10 03:41 PM
04/08/10 03:41 PM
Cincinnati, Ohio
Cincinnati, Ohio
Sounds like you have to swap calibers side to side.
Re: Did I put my brakes together backwards? [Re: Challenger 1] #664423
04/08/10 04:02 PM
04/08/10 04:02 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I hope it's that easy but I'm looking at the link that RodStRace provided and there is a picture in there that clearly shows the caliper mounting bracket on the front side of the rotor and mine is on the rear so unless I'm missing something did I put the whole D*** assembly together wrong?
I could get longer hoses I suppose but this is a fresh build and I have already bought everything new and besides I'd like to have at least one thing put back together the way the factory did it!
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664424
04/08/10 04:12 PM
04/08/10 04:12 PM
wisconsin
swifter Offline
swifter  Offline
wisconsin
Hey I did the same on my 70 a-body,But the hoses worked fine and I was told as long as the bleeders are on top and the hoses do not get bound up in any way leave it alone and that is just what I did--Steve
2007 Ram 2500 Cummins 2008 Dodge Nitro 1970 340 Valiant Duster
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664425
04/08/10 04:35 PM
04/08/10 04:35 PM
I'd suggest popping the ball joints loose w a puller as opposed to a pickle fork and swapping the spindles to get the calipers/adapters on the front sides then your hoses/everything are all good and you are only out some extra time & no damage done and you've gained some useful info/experience
Re: Did I put my brakes together backwards? [Re: swifter] #664426
04/08/10 04:40 PM
04/08/10 04:40 PM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
In some applications, there can be a benefit / clearance improvement by swapping spindles from side-to-side (and making sure to install the calipers where the bleeder is UP). I actually did this when installing U.S. disk brakes on my Aussie Valiant.
Of course in the O.P.'s case it was a mistake, but I'm just sayin'...
Down to just a blue car now.
Re: Did I put my brakes together backwards? [Re: RapidRobert] #664427
04/08/10 05:32 PM
04/08/10 05:32 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I was thinking the same thing, I'll have to see if I have a puller because I did destroy all the rubber boots when I took apart the old stuff using my pickle fork - If I don't have a puller I'll pick one up.
Time to head home and have a beer and laugh about this one - thanks again guys!
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664428
04/08/10 05:36 PM
04/08/10 05:36 PM
BDW Online content
BDW  Online Content
AutoZone will loan you a puller for free.
Re: Did I put my brakes together backwards? [Re: 70BIRD] #664429
04/08/10 05:36 PM
04/08/10 05:36 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
yup, did the same thing, had spindels off a couple of months, got talking with buds and put them on wrong sides and didn't notice till i started putting the brakes on. (love the banna)
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
