Re: SPRING PRESSURE ON MOPAR .590 CAM
[Re: deaks]
#663855
04/11/10 01:48 PM
04/11/10 01:48 PM
Posts: 415 Peru
cbarracuda
Peru
i have got RPM springs with inners for my old motor which had a R280 roller cam, is this too much and if so, will the RPM springs without the inners be sufficent. Mick
Isky 8005 is best installed at 1.90, the rpm are also good installed at 2.00"
[Re: deaks]
#663856
04/11/10 03:23 PM
04/11/10 03:23 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
I have nothing to measure them pressure wise but the eddy site claims they are good up to .600 lift, so rather than wipe the cam i'll try them and if they dont work out, i'll get my wallet out again. Mick
My Eldelbrock headsheet rates the EDDY RPM springs 120 lbs @ 1.88 ht.
Back in 06 Dwayne Porter measured some of my Hughes springs and for Comparison he sent me the measurements on a New Eddy RPM spring, they were;
127 lbs @ 1.900
140 lbs @ 1.860
297 lbs @ 1.400
330 lbs @ 1.300 mike
