Re: Who else is running a Powerglide in their Mopar ?
[Re: W8n2DustU]
#662994
04/07/10 08:12 AM
04/07/10 08:12 AM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
JW Glide , converter, transbrake V/B , Flywheel , and Bell Housing adapter .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: SLOW67]
#662998
04/07/10 10:52 PM
04/07/10 10:52 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Not me, i run a turbo 400 with a 2:10 first gear on my TT5 supercharged dart. ![](/ubbthreads/images/graemlins/thumbs.gif) It all depends on your combo, 1/4 or 1/8 and your goals whether or not the glide is the right choice.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: Leigh]
#663000
04/07/10 11:09 PM
04/07/10 11:09 PM
Posts: 705 Michigan
Hemiroid
I would think the brutal low end torque, of a crank driven blower, would play directly into the hands of a glide. I'm too tired to check, what is the starting line ratio of a typical glide, versus the 2.10 ratio that you are using?
1.76
[Re: Leigh]
#663002
04/07/10 11:34 PM
04/07/10 11:34 PM
bigtimeauto
Trophy Winner
Trophy Winner
Hmmm maybe i am doing it all wrong and should put a glide in ![](/ubbthreads/images/graemlins/tsk.gif)
It seems the strongest aftermarket gear set is a 1.80 for the glide.
Now if all your worried about is bracket racing go get that glide but if you are looking to go fast in the 1/4 more gears always seems to win out. Keeping the engine in its happy spot will do more for a low ET than a big RPM drop.
My car? As for getting off the starting line and getting down the track there are many ways to do that. BUT the biggest problem that everybody seems to miss is the rpm drop between the gear changes with a blower car. the less drop the boost stays...
Like i said it all depends on your combo and goals.
[Re: SG duster]
#663004
04/08/10 03:38 AM
04/08/10 03:38 AM
Posts: 2,935 Finalnd, Perkele
jyrki
Finalnd, Perkele
Count us in too. I bought a JW trans from racingjunk, should be good for 1800hp, got it for 2700$ and it was unused. 1.80 gear ratio first, and PTC 10" steel stator converter. 3470 lbs, DOT tires; 1.26 60 ft and 7.89/175 mph on pump gas. There is still room for improvement in the launch, need more experience. No rpoblem with the RPM drop, We leave at 4000 rpm, the stall is about 6200 on the current boost and we shift at 7100; after the shift the rpm drops to 6200 and we cross the line against the limiter at 7500.
Plynouth VIP '67 TT IC EFI
[Re: jyrki]
#663005
04/08/10 10:11 AM
04/08/10 10:11 AM
bigtimeauto
Trophy Winner
Trophy Winner
If i'm not mistaken you have a turbo car. I said blower. Actually a turbo car loves the glide because it keeps the turbos loaded.
like i said, depends on the combo and goal.
[Re: The Shocker]
#663006
04/08/10 01:12 PM
04/08/10 01:12 PM
Posts: 418 Laredo, Texas USA
hugo
Laredo, Texas USA
69 Road runner ladder bar susp. and stturts in front weight is 2900. The engine is a low deck 499ci with indy 440-1 flowing 358 at 700. Cam is rather small 269int and 273ex with a 696 lift. Tires are 32X14.5 with 4.56 gears. Coan powerglide and 8inch converter to the specs of engine. Engine made 765 at 6300 and 695tq at 4900. Car has been 1.29 in the 60ft and 9.28 at 143.7 at 3700ft. I AM VERY HAPPY WITH MY GLIDE ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: jamesc]
#663008
04/08/10 06:12 PM
04/08/10 06:12 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Glides are the greatest thing sense sliced bread. The #1 tranny in the world Yata Yata Yata.
Will sell either one of mine or both and they have some great parts inside. Both use stock GM case with JW bell and tail housing all aftermarket internals.
[Re: Irun5snd8th]
#663009
04/08/10 06:23 PM
04/08/10 06:23 PM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
Put one in mine at the end of last year and I love it. 3000lbs 416 small block. Fastest the car had been in the 1/8th was 6.22 with the setup at the time and I went 6.26 with the glide in it. I will say it honestly lost .04 in 60 ft and .06 total.
Just wondering, but if the car slowed down, why do you love it so much? ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: dizuster]
#663010
04/08/10 09:03 PM
04/08/10 09:03 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
Its proly more consistant with the Glide than the 727.Only have one shift to hit at the right rpm , instead of two ...
