Page 2 of 7 1 2 3 4 5 6 7
Re: Who else is running a Powerglide in their Mopar ? [Re: W8n2DustU] #662994
04/07/10 08:12 AM
04/07/10 08:12 AM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
JW Glide , converter, transbrake V/B , Flywheel , and Bell Housing adapter .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Who else is running a Powerglide in their Mopar ? [Re: chryco] #662995
04/07/10 09:31 PM
04/07/10 09:31 PM
Sherman Texas
The Shocker Offline OP
Sherman Texas
Thanks for the feedback guys.Anyone else ???
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: Who else is running a Powerglide in their Mopar ? [Re: The Shocker] #662996
04/07/10 09:38 PM
04/07/10 09:38 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I'd have one bolted into my 10.30, 3185 lb S/P Dart, tomorrow, if I wasn't poorer than a church mouse. Best bracket/headsup idea since sliced bread.. and I wear pentastar grunders.
Re: Who else is running a Powerglide in their Mopar ? [Re: The Shocker] #662997
04/07/10 10:05 PM
04/07/10 10:05 PM
NC
SLOW67 Offline
SLOW67  Offline
NC
I really want to make the switch in my valiant but I cant find anyone to swap me my bb to glide bell for a sb one....
Re: Who else is running a Powerglide in their Mopar ? [Re: SLOW67] #662998
04/07/10 10:52 PM
04/07/10 10:52 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Not me, i run a turbo 400 with a 2:10 first gear on my TT5 supercharged dart.
It all depends on your combo, 1/4 or 1/8 and your goals whether or not the glide is the right choice.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Who else is running a Powerglide in their Mopar ? [Re: bigtimeauto] #662999
04/07/10 11:07 PM
04/07/10 11:07 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I would think the brutal low end torque, of a crank driven blower, would play directly into the hands of a glide. I'm too tired to check, what is the starting line ratio of a typical glide, versus the 2.10 ratio that you are using?
Re: Who else is running a Powerglide in their Mopar ? [Re: Leigh] #663000
04/07/10 11:09 PM
04/07/10 11:09 PM
Hemiroid Offline
Hemiroid  Offline
1.76
Re: Who else is running a Powerglide in their Mopar ? [Re: Hemiroid] #663001
04/07/10 11:10 PM
04/07/10 11:10 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Who else is running a Powerglide in their Mopar ? [Re: Leigh] #663002
04/07/10 11:34 PM
04/07/10 11:34 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Hmmm maybe i am doing it all wrong and should put a glide in
It seems the strongest aftermarket gear set is a 1.80 for the glide.
Now if all your worried about is bracket racing go get that glide but if you are looking to go fast in the 1/4 more gears always seems to win out. Keeping the engine in its happy spot will do more for a low ET than a big RPM drop.
My car?
As for getting off the starting line and getting down the track there are many ways to do that. BUT the biggest problem that everybody seems to miss is the rpm drop between the gear changes with a blower car. the less drop the boost stays...
Like i said it all depends on your combo and goals.
Re: Who else is running a Powerglide in their Mopar ? [Re: bigtimeauto] #663003
04/08/10 01:24 AM
04/08/10 01:24 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
count me in too, I brought mine built from Huggo at www.raceglides.com.au cheaper than I could buy 727 parts & it came with two converters & a gauretee
Re: Who else is running a Powerglide in their Mopar ? [Re: SG duster] #663004
04/08/10 03:38 AM
04/08/10 03:38 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Count us in too. I bought a JW trans from racingjunk, should be good for 1800hp, got it for 2700$ and it was unused. 1.80 gear ratio first, and PTC 10" steel stator converter. 3470 lbs, DOT tires; 1.26 60 ft and 7.89/175 mph on pump gas. There is still room for improvement in the launch, need more experience. No rpoblem with the RPM drop, We leave at 4000 rpm, the stall is about 6200 on the current boost and we shift at 7100; after the shift the rpm drops to 6200 and we cross the line against the limiter at 7500.
Plynouth VIP '67 TT IC EFI
Re: Who else is running a Powerglide in their Mopar ? [Re: jyrki] #663005
04/08/10 10:11 AM
04/08/10 10:11 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
If i'm not mistaken you have a turbo car. I said blower.
Actually a turbo car loves the glide because it keeps the turbos loaded.
like i said, depends on the combo and goal.
Re: Who else is running a Powerglide in their Mopar ? [Re: The Shocker] #663006
04/08/10 01:12 PM
04/08/10 01:12 PM
Laredo, Texas USA
hugo Offline
hugo  Offline
Laredo, Texas USA
69 Road runner ladder bar susp. and stturts in front weight is 2900. The engine is a low deck 499ci with indy 440-1 flowing 358 at 700. Cam is rather small 269int and 273ex with a 696 lift. Tires are 32X14.5 with 4.56 gears. Coan powerglide and 8inch converter to the specs of engine. Engine made 765 at 6300 and 695tq at 4900.
Car has been 1.29 in the 60ft and 9.28 at 143.7 at 3700ft.
I AM VERY HAPPY WITH MY GLIDE
Re: Who else is running a Powerglide in their Mopar ? [Re: hugo] #663007
04/08/10 02:17 PM
04/08/10 02:17 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
one thing about the glide is you have to make sure is has the right converter, they're very sensitive to converter selection.
Re: Who else is running a Powerglide in their Mopar ? [Re: jamesc] #663008
04/08/10 06:12 PM
04/08/10 06:12 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Glides are the greatest thing sense sliced bread. The #1 tranny in the world Yata Yata Yata.
Will sell either one of mine or both and they have some great parts inside. Both use stock GM case with JW bell and tail housing all aftermarket internals.
Re: Who else is running a Powerglide in their Mopar ? [Re: Irun5snd8th] #663009
04/08/10 06:23 PM
04/08/10 06:23 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Put one in mine at the end of last year and I love it. 3000lbs 416 small block. Fastest the car had been in the 1/8th was 6.22 with the setup at the time and I went 6.26 with the glide in it. I will say it honestly lost .04 in 60 ft and .06 total.
Just wondering, but if the car slowed down, why do you love it so much?
Re: Who else is running a Powerglide in their Mopar ? [Re: dizuster] #663010
04/08/10 09:03 PM
04/08/10 09:03 PM
Sherman Texas
Sherman Texas
Its proly more consistant with the Glide than the 727.Only have one shift to hit at the right rpm , instead of two ...
Re: Who else is running a Powerglide in their Mopar ? [Re: The Shocker] #663011
04/08/10 09:19 PM
04/08/10 09:19 PM
okla.
sam64 Offline
sam64  Offline
okla.
which is the main reason for the switch,fastest doesn't always put on the win light.saftey is also on some of those minds.
Re: Who else is running a Powerglide in their Mopar ? [Re: jamesc] #663012
04/09/10 12:12 AM
04/09/10 12:12 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
it all depends on what your goal is. i've said it before there's a reason the powerglide is the most popular racing transmission.
Reason number one is most cars race chevt motors and it is the toughest chevy trans.
Reason number 2 is Because every one can brag about runing 4.88 gears with them when it would take off too fast with a 2.45 1st gear 727.
Reason number 3 is it is admitedly a simple trans, takes more brains to re-build a 727 but a PG is so easy a caveman could do it.
I have never heard of any one going faster useing a PG that a 727 with the correct gear ratio. If you hear of someone that went faster it was because they had the wrong gear and or converter in the 727 plain and simple.
You can run more consistant with a PG because you have one less shift to hit at the right time (who says you have to hit 3rd in a 727?) but you will either leave some TQ on the table at the starting line or spin un nessacary RPM at the finish line.
Re: Who else is running a Powerglide in their Mopar ? [Re: HotRodDave] #663013
04/09/10 12:25 AM
04/09/10 12:25 AM
jamesc Offline
jamesc  Offline
yes you're right, we're all idiots what was i thinking...
torqueflite is the best transmission ever made, after all it's a chrysler product. why would anyone want a inexpensive, strong, lightweight, consistent transmission when they can have a torqueflite instead.
seems a lot of mopar racers (not test and tuners) are taking a liking to the glide
what kind of tool brags about axle ratio?
so complexity makes a transmission better?
906 heads, 727s and danas for everyone...no wonder we're left behind
