Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661276
04/06/10 04:40 PM
04/06/10 04:40 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
I bought a set of the PAC springs, see the first post for the details. Thanks to all for the help
You may know, Cab, that PAC is all Jason uses on our motors and we buzz them pretty high.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: BobR] #661277
04/06/10 05:45 PM
04/06/10 05:45 PM
Cab_Burge Online work OP
Cab_Burge  Online Work OP
I did not know that, the last time I talked to him(a long time ago,4 or 5 yrs) about valve springs he was using Manley, Nextext and some Crowers, I think. Thanks for the heads up BTW, how you guys do in Bakerfields, Doug won't answer his shop phone when I call I figured he lost or screwed up and is ashame to talk to me
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661278
04/06/10 05:59 PM
04/06/10 05:59 PM
Arizona
Chris'sBarracuda Offline
Arizona
Interesting post here.. I'm sold on PAC..
Yeahdoug wrote:
Lem Evans wrote:221424-16 Manley Nextex . Erson spring looks to be the same unit....blue stripe deal .
Some fatigue test data I did comparing the 221424 polished and non polished to our PAC-1224/1324 (our copy of that spring with our own flavor of processing).
These are the cycle counts for the first failures of each part. All springs were tested to the same 1.300" stroke (overstressed to induce failures).
Manley 221424 STD: 4,995 cycles.
Manley 221424P Electro-polished: 22,277 cycles.
PAC-1324: 866,530 cycles.
PAC-1224: 571,668 cycles.
Yeahdoug,
Here is the whole thread..
http://www.speedtalk.com/forum/viewtopic...726b3399799cfa1
Chris..
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Chris'sBarracuda] #661279
04/06/10 09:54 PM
04/06/10 09:54 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Sounds familiar,,,Engine Works, available @ Nickles Performance in Tenn. #985-16 spring will get you about 225# @ 1.95". I have used them alot on small block Chev. They will go around 680# open and are good to .720" lift @ 1.95". I will have to look later,, but I think the #987 will give you more seat pressure with similar open pressure. Possibly a + .050" loc with the 987 to get where you want to be. I have had good luck with the 985 for years, usually good for a season on dirt track motors. Probably a LOT more on drag applications. Forgot to add, VERY affordable @ $200.00+- few bucks.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661280
04/07/10 02:11 AM
04/07/10 02:11 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
This is the Crower Ti retainers I used with the 1225/1325 PAC springs:
Crower #86067D-16. 1.500 od, 0.725id, cost $239.95 from summit racing.
http://www.summitracing.com/parts/CRO-86067D-16/
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: 451Mopar] #661281
04/07/10 11:57 AM
04/07/10 11:57 AM
pa
572charger Offline
572charger  Offline
pa
comp 943 springs set at 1.950 are 235-240 on the seat ! ive got a roller cam 720 lift, got 4 years of racing and street driving work perfect 9.60s at 141.75 and they don't wear stuff out and no broken parts !!!!!!!!
606 hemi pump gas best 9.60 at 142mph on motor
05 hemi daytona 1500 go-mango 4wd quadcab
2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: 572charger] #661282
04/07/10 12:12 PM
04/07/10 12:12 PM
The springs on there where Comp 1.550 roller springs, I don't remember the number, sorry. They have lost between 25 and 30 lbs pressure on the seat(275 lbs. to 255) and over the nose( 675 lbs. down to 250 lbs), which is probally no big deal on most motors. This motor broke a 3/8x.083 pushrod during the first set of dyno test, it also hurt the cam and broke the top off of one set of rollers. I fixed the motor and ended up replacing the 3/8x.083 pushrods with a set of 3/8x.120 wall Manton sereis 5 during the next dyno tests, the pushrods made 8 hp more and 7 ft. lbs torque gradually from 4200 all the way up to 6500 RPM. This leads me to thank, especially after talking to Terry Manton, that a bigger, stronger pushrod is needed along with some more spring pressures. The cam lobes are capable of 9000+ plus according to the folks at comp Cams Hopefully I'm not a dead horse The rockers are a set of T&D 1.65 ratio on both sides. The new springs are on the way and I will dyno it again to see what is does after freshening it up. It burnt two pistons up on the last dyno session,but that is another story.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661283
04/07/10 12:32 PM
04/07/10 12:32 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Got too agressive in the final and went about 6" before blowing the tires off. We're still learning how to race with turbos.
