Re: Copper head gaskets, sealing issues [Re: instigator] #660929
04/08/10 08:04 PM
04/08/10 08:04 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
What kind of paint?
Re: Copper head gaskets, sealing issues [Re: nhramark] #660930
04/08/10 08:15 PM
04/08/10 08:15 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Bob, I used Hylomar on my copper head gaskets and have had no leaks. You can get it just about anywhere too. Good luck.
i have had zero leak issues with Hylomar...NA, 13.5 comp, o-ringed (block only), SCE gaskets
Re: Copper head gaskets, sealing issues [Re: jughed] #660931
04/08/10 10:00 PM
04/08/10 10:00 PM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Copper head gaskets, sealing issues [Re: jughed] #660932
04/08/10 10:02 PM
04/08/10 10:02 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Bob find some spray hylomar and put the old copper gaskets on there. It's leaking around the water ports and not the cylinder area.
I doubt you would have a leak but if you did then try the Moroso or Pioneer sealer.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660933
04/08/10 10:21 PM
04/08/10 10:21 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
just put my heads on today.i just wanted to share a pic as long as it is on the topic.
Re: Copper head gaskets, sealing issues [Re: instigator] #660934
04/08/10 10:43 PM
04/08/10 10:43 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Sorry,
http://www.permatex.com/products/Automot...ket_Sealant.htm
I used that to with no leaks last year on a copper shim not even a gasket???
Re: Copper head gaskets, sealing issues [Re: blownzoom440] #660935
04/08/10 11:41 PM
04/08/10 11:41 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
Peanut butter?
Re: Copper head gaskets, sealing issues [Re: CokeBottleKid] #660936
04/09/10 04:17 AM
04/09/10 04:17 AM
ELYRIA,OH
ELYRIA,OH
Peanut butter?
no it is copper plus silicone.
Re: Copper head gaskets, sealing issues [Re: blownzoom440] #660937
04/09/10 04:23 AM
04/09/10 04:23 AM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
So to 'aneal' my copper gaskets I need to get it glowing hot with a torch and dip it in water or spray it with water. How long should I wait to install it after that?
Re: Copper head gaskets, sealing issues [Re: ProSport] #660938
04/09/10 09:07 AM
04/09/10 09:07 AM
Detroit, MI
Detroit, MI
DO NOT QUENCH IT... let it air cool.
Re: Copper head gaskets, sealing issues [Re: CokeBottleKid] #660939
04/10/10 06:21 PM
04/10/10 06:21 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
Well after examining my head gaskets it appears that I did a terrible job of getting the silicone in the right spots and literally missed half the hole in a few places. I also didn't scotch brite the gaskets to help the silicone stick to it. SCE has some copper head gaskets that are .032 thick so I think I'm gonna try those. My pistons are .016 in the hole and last years Summit copper gaskets were .043 thick so quench was .059. So with the 32's I'll be at a better .048.
I'm headed to Superformance right now to pick up some oil pan gaskets and show Greg my Summit copper gaskets.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660940
04/10/10 07:22 PM
04/10/10 07:22 PM
ELYRIA,OH
ELYRIA,OH
dont feel bad about missing spots.each time i do mine i have to take pics to insure myself several times i got everything.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660941
04/10/10 10:18 PM
04/10/10 10:18 PM
Akron, Ohio
ProSport Offline OP
ProSport  Offline OP
Akron, Ohio
I will do that Dave.
And thanks for the photo Mike, that really helped me to see what I did wrong with mine.
Now I have to decide what sealer to use as you guys have given several great ideas. I was leaning towards the one that 'Instigator' posted but RoadHazard and a couple others have told me that Hylomar or spray hylomar is the way to go, then there's also this Yamabond.
Re: Copper head gaskets, sealing issues [Re: ProSport] #660942
04/10/10 10:44 PM
04/10/10 10:44 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Nice to meet you and the wife Bob
Use Yamabond if you want to take them off with a BF Prybar
Hylomar is a non hardening and much easier to work with. It's been around for years in the aircraft industry. They used to apply it to aluminum engine cases and seal them with pure silk thread, that's it!
Post deleted by Defbob [Re: ProSport] #660943
04/11/10 10:59 AM
04/11/10 10:59 AM
Re: Copper head gaskets, sealing issues #660944
04/11/10 11:18 AM
04/11/10 11:18 AM
ELYRIA,OH
ELYRIA,OH
just from my experience i found the silicone to spread under head/bolt tq and putting on as thin a layer as possable was good enough.it can get pushed into the head oil passage to the rockers and could stop oil to 1 if it would happin.my luck that is.i have pics of the block and heads to show the pattern of squish.
