Page 2 of 3 1 2 3
Re: Freeing stuck fuel pump pushrod [Re: Pacnorthcuda] #660078
04/04/10 01:32 PM
04/04/10 01:32 PM
Pac thanks for the heads up. I'm wondering if any other vendor makes a (known) good one.
Re: Freeing stuck fuel pump pushrod [Re: RapidRobert] #660079
04/04/10 04:29 PM
04/04/10 04:29 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I hope the one from 440Source doesnt have this problem
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Freeing stuck fuel pump pushrod [Re: Pyper70] #660080
04/04/10 04:39 PM
04/04/10 04:39 PM
the way i found out i was having this problem is my motor would not stay running, i'd pour a little fuel down the carb and she would fire and then a few seconds later, my engine would stall, at 1st i thought it was the fuel pump but when i dropped the fuel pump, the pushrod wouldnt come out. after finally removing it, it lost a good 1/4" and it was totally mushroomed, i saved it for years over my kitchen sink, i just threw it out a few months ago.
i think i put another MP one in, i havent had a problem yet but i think i need to inspect it again.
Re: Freeing stuck fuel pump pushrod #660081
04/04/10 08:45 PM
04/04/10 08:45 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
I see Moroso, Comp, Crane, Howards etc etc make the fuel pump pushrods for small & big block Chevs but not BB Mopars
As a turner I would have no problem making a pushrod but what to make it from & the hardening process is what's stopping me, any expert advice?
Re: Freeing stuck fuel pump pushrod [Re: nz383man] #660082
04/04/10 09:59 PM
04/04/10 09:59 PM
That's a good idea
Re: Freeing stuck fuel pump pushrod [Re: RapidRobert] #660083
04/05/10 04:18 AM
04/05/10 04:18 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Jegs Chev push rod - Precision made from 4130 chrome moly tubing. Made in the USA.
Moroso - Lightweight design with hardened ends reduces reciprocating mass
ARP - They're made from premium grade aerospace chrome moly and centerless ground to precise diameter. A hollow core serves to reduce the reciprocating mass.
Barry Grant - Special lightweight high strength tubular push rod.
Comp Cams - Lightweight tubing with bronze tip for steel cams, Lightweight tubing For cast iron cams.
Manley - These pushrod is made for 4130 chrome mole steel tubing.
Carter - Chromemoly
Crane - Chromemoly
MP - Chromemoly
Crower - The Crower fuel pump pushrod is manufactured from lightweight steel tubing that is heat-treated for added strength. The bronze tip ensures proper surface mating with the fuel pump eccentric lobe on 8620 steel billet camshafts. This surface compatibility eliminates the wear problems associated with stock designs. For cast iron hydraulic and solid cams they offer a lightweight model with a steel tip at each end to protects against wear.
Well I guess I'm going to have a crack at making my own, from my experiance & the horror stories I hear here I can't do much worse than MP
Re: Freeing stuck fuel pump pushrod [Re: nz383man] #660084
04/05/10 07:51 AM
04/05/10 07:51 AM
Maryland USA
beatgoeson Offline OP
Maryland USA
Thats for sure, I can't believe none of the manufacturers mentioned make one for Mopar its Frustrating. I'm not sure what to do I may call 440 Source today but that may just be the Mopar piece as well.
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #660085
04/05/10 10:17 AM
04/05/10 10:17 AM
Do post what they have to say and if I get one of theirs I might take it out after a period of time & simply check it.
Re: Freeing stuck fuel pump pushrod [Re: RapidRobert] #660086
04/05/10 10:40 AM
04/05/10 10:40 AM
Midwest
fuseable Offline
fuseable  Offline
Midwest
What is the length of a new pushrod?
Re: Freeing stuck fuel pump pushrod [Re: fuseable] #660087
04/05/10 10:43 AM
04/05/10 10:43 AM
I think 3&1/4" on the nose
Re: Freeing stuck fuel pump pushrod [Re: RapidRobert] #660088
04/08/10 06:15 AM
04/08/10 06:15 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
I found the length given for a MP P529569 pushrod was 3.242" looks like they built .008" of wear into it from new
Re: Freeing stuck fuel pump pushrod [Re: nz383man] #660089
04/08/10 10:17 AM
04/08/10 10:17 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
What is the diameter? If it is a common size, maybe a guy could get a drop scrap of O1 or other good tool steel from a machine shop. A drop that length might be free. Or they might cut to length for a nominal fee. Just a thought...
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #660090
04/08/10 11:18 AM
04/08/10 11:18 AM
Eastern North Carolina
riverman Offline
riverman  Offline
After all the talk on this thread, I pulled out the new one I put in this February along with a new fuel pump and vapor separator.
Be aware - it was starting to hollow out on one end, this after less than 600 miles. The old rod had been in up to 103,000 miles (I've put on 3000 miles since I got it so at least that many) and there is absolutely no wear on the face of both ends. Got the rod at Mancini's just before Christmas so the current batch is highly suspect. Calling Mancini to alert them to the situation. Thanks for all your help. Saved an engine.
Re: Freeing stuck fuel pump pushrod [Re: Scott Carl] #660091
04/09/10 06:55 AM
04/09/10 06:55 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
The one I took out was a couple of thou under 7/16"
Re: Freeing stuck fuel pump pushrod [Re: riverman] #660092
04/09/10 05:31 PM
04/09/10 05:31 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
What did Mancini say? I emailed them about mine and will report their response.
Re: Freeing stuck fuel pump pushrod [Re: ireland383] #660093
04/09/10 06:01 PM
04/09/10 06:01 PM
riverman Offline
riverman  Offline
Two days - no response. No thank you, we will look into it, etc.
Re: Freeing stuck fuel pump pushrod [Re: riverman] #660094
04/10/10 05:49 AM
04/10/10 05:49 AM
Australia
charger RTSE Offline
Australia
I bought one Airtex brand.On the box it says made in USA.
Any problems with this brand?
Re: Freeing stuck fuel pump pushrod [Re: charger RTSE] #660095
04/10/10 07:22 AM
04/10/10 07:22 AM
scratchnfotraction Offline
I am fixing to up the stock fuel pump on my 440
was gonna use a carter or holley pump
whats the opinion here..stay with the 75,000 mile stock one thats in there..correct??
should i even see if it will come out and measure it any ways??
this is
I am at the piont of doing the fuel line plumbing and could go elect or mech
I need longevity out of either one
Re: Freeing stuck fuel pump pushrod [Re: scratchnfotraction] #660096
04/10/10 09:32 AM
04/10/10 09:32 AM
Michael pull it and see where you're at, nothing beats a good ole fashioned visual inspection and if you dont you wont know how it's holding up so far
Re: Freeing stuck fuel pump pushrod [Re: RapidRobert] #660097
04/11/10 09:39 AM
04/11/10 09:39 AM
I think I will do that for sure now
Page 2 of 3 1 2 3
