Crane Gold Roller Rockers #659983
04/03/10 03:11 PM
04/03/10 03:11 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
I purchased a set of these recently and when I place them on my Stealth heads the top mounting aluminum spacer blocks are about 1/4 inch from the mating surface on the head, is this normal and do you know what kind of bolts to use to mount these, I was thinking about 12 point heads, Thanks Rodger
Re: Crane Gold Roller Rockers [Re: 69 GTX] #659984
04/03/10 05:47 PM
04/03/10 05:47 PM
organ
maximum entropy Offline
organ
that's normal for the blocks. use good hardware- grade eight minimum, and as long as possible without bottoming out.
Re: Crane Gold Roller Rockers [Re: maximum entropy] #659985
04/03/10 06:09 PM
04/03/10 06:09 PM
Canada
69 GTX Offline OP
69 GTX  Offline OP
Canada
Thanks very much, Rodger
