I went through the winch gauntlet.
First I bought an identical one(with the crank) off E-bay rated a 5000lb.
It lasted 3 times pulling a rolling E body on my trailer then the cable got all twisted up going onto the spool and locked up the motor, never to work again.
The second was the camo one with the wireless remote from Harbor Freight, it died(motor locked up) on the very first pull with the same drivetrain-less E-body. I took it back to HF
I then bought this one off E-bay.
3000lb. Viper with synthetic rope.
I bought the identical winch for my ATV a few years ago and it has worked flawlessly and I have abused it pretty good.
http://cgi.ebay.com/ebaymotors/VIPER-Max...sQ5fAccessoriesThis one has worked perfectly for a couple years.
I bought an ATV plate mount that the winch bolts to and it has a 2" receiver insert on the other end.
I welded a 2" receiver tube to a plate and bolted the plate to front of my trailer floor with bolts going through the floor and under the trailer frame to another plate.
The mounted winch slides in and out of the receiver tube.
So far so good.
