Template for adding weight to 904 converter for 360 ? #65659
05/29/08 12:16 PM
05/29/08 12:16 PM
ohio
70shaker6pk Offline OP
super gas
super gas
ohio
Does anyone have picture they can post of the template for installing the weights to a 904 converter for a 360 engine? Or be able to explain exact location.. Thanks for help.
Re: Template for adding weight to 904 converter for 360 [Re: 70shaker6pk] #65660
05/29/08 01:49 PM
05/29/08 01:49 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
i would just buy the B+M flexplate and be done with it , then you can run any neutral balance convertor your heart chooses
Re: Template for adding weight to 904 converter for 360 ? [Re: 70shaker6pk] #65661
05/29/08 01:55 PM
05/29/08 01:55 PM
Valrico FL
1toolguy Offline
1toolguy  Offline
Valrico FL
The easiest way to solve this problem is to by the B&M flexplate for the external balance engine. It's only $80 and it's a lot less hassle.
Re: Template for adding weight to 904 converter for 360 [Re: 1toolguy] #65662
05/29/08 02:33 PM
05/29/08 02:33 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
Very simple to take a JY 360 converter and knock the weights off it and tack to a different converter. Orient be laying the 360 converter and the non weighted converter next and using teh flexplate lugs as an index to each other and locate. Also if the non weighted converter is OEM type the weights will go 1 on each side of the drain if so equipped. Yep the B&M plate is nice but more spendy.
Re: Template for adding weight to 904 converter for 360 [Re: MoparforLife] #65663
05/29/08 08:44 PM
05/29/08 08:44 PM
ohio
super gas
super gas
ohio
Thanks for the help, I have a 727 weighted converter so i will knock the weights off it and weld them in the same location, on the 904. Thanks again
Re: Template for adding weight to 904 converter for 360 ? [Re: 1toolguy] #65664
05/30/08 08:54 AM
05/30/08 08:54 AM
Spring, Texas
RedFish Offline
super street
RedFish  Offline
super street
Spring, Texas
And I might just know someone who's trying to get rid of a B&M sb 904 flex plate.
Howard
You don't stop playing games when you get old, You get old when you stop playing games.
