Re: How hard to convert post car to hard top? [Re: PAINT IT BLACK] #656075
03/30/10 09:06 PM
03/30/10 09:06 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Sounds like something seen on failblog.org
That's why I asked. So I didn't "fail".
I would be more than happy to help.....I just did this Suburban roadster.
Re: How hard to convert post car to hard top? [Re: OzHemi] #656076
03/31/10 06:29 PM
03/31/10 06:29 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If you have a donor vehicle, you don't need a 70 Coronet for the required pcs, any 69-70 B body, Plymouth or Dodge, including Charger will yeild all the pcs required, you could use a 68, but the glass runners are narrower, and the door glass rear vertical chrome is smooth in appearance, unlike the 69/70 pcs, plus the 68 stuff as far as regulators don't quite line up bolt hole wise, but would work ,....you'll need to change out the door glass as it's different between post/hardtop, any 69-70 B body, including Charger glass will fit, including vent window
IMHO the hardtop looks so much better than the post,....thumb your nose at originality, do the car the way you want,......Pssst, Black on Black would look REALLY Killer on that Bee!
Re: How hard to convert post car to hard top? [Re: DAYCLONA] #656077
03/31/10 06:30 PM
03/31/10 06:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Re: How hard to convert post car to hard top? [Re: PAINT IT BLACK] #656078
03/31/10 07:20 PM
03/31/10 07:20 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
Re: How hard to convert post car to hard top? [Re: PAINT IT BLACK] #656079
03/31/10 08:38 PM
03/31/10 08:38 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
I think with either car you still have a vent post to tie a belt to...
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
