brakes #655401
03/29/10 09:25 PM
03/29/10 09:25 PM
mo. usa
U
ukieone Offline OP
ukieone  Offline OP
U
mo. usa
what is involved in changing brakes from power to manual brakes? thanks.
Re: brakes [Re: ukieone] #655402
03/29/10 09:30 PM
03/29/10 09:30 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
What year, and model?
Re: brakes [Re: Dougsmopars] #655403
03/29/10 09:34 PM
03/29/10 09:34 PM
mo. usa
U
ukieone Offline OP
ukieone  Offline OP
U
mo. usa
its a 69 r/t with 440 and disc setup off of a 73 a body.
Re: brakes [Re: ukieone] #655404
03/29/10 09:52 PM
03/29/10 09:52 PM
Dougsmopars Offline
Dougsmopars  Offline
Get a manuel disc master and correct pedal rod. Manuel brake cars don't use the pivot linkage. They also use a different plate behind the master.
Re: brakes [Re: Dougsmopars] #655405
03/29/10 09:57 PM
03/29/10 09:57 PM
mo. usa
U
ukieone Offline OP
ukieone  Offline OP
U
mo. usa
thanks, that will get me going in the right direction.
Re: brakes [Re: Dougsmopars] #655406
03/29/10 10:22 PM
03/29/10 10:22 PM
I'd contact Ehrenberg or Dr diff to purchase the correct bore alum M/C so you will end up with the bore size that will give you the right pedal effort the 1st time which if off will get old real quick. As said a manual pedal push rod & maybe a MP adjustable length one. A manual brake M/C will have a wide groove inside the M/C piston cavity (The "thimble" so a piece of vac line on the end of the end of the pushrod) to retain it which is not needed on a PB setup.
