Can you run Vintage Direct Connection Valve Covers #655372
03/29/10 09:13 PM
03/29/10 09:13 PM
Fort Workin Tx
Day2Runner Offline OP
Fort Workin Tx
without baffles on the street under PCV and crankcase filter and if not can you add the baffles ??
Thx Moparts just asking
Dan H
Re: Can you run Vintage Direct Connection Valve Covers [Re: Day2Runner] #655373
03/29/10 09:29 PM
03/29/10 09:29 PM
NJ
440challenger Offline
NJ
i have a set and took them off. could never get them to seal
Re: Can you run Vintage Direct Connection Valve Covers [Re: Day2Runner] #655374
03/29/10 09:32 PM
03/29/10 09:32 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I wouldn't run without baffles. oil and oil mist is thrown off the rockers. The baffle helps keep the breather free of oil residue.
Re: Can you run Vintage Direct Connection Valve Covers [Re: 440challenger] #655375
03/30/10 01:00 AM
03/30/10 01:00 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
I have a chrome set that are JUNK! There isn't enough of a lip to hold a gasket down. Classic Low-bidder crappola.
Cory
Re: Can you run Vintage Direct Connection Valve Covers [Re: Day2Runner] #655376
03/30/10 02:34 AM
03/30/10 02:34 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Nice looking valve covers! Running without the baffles at the dragstrip isn't a problem because the engine is operated at full throttle where there is little to no vacuum. Driving on the street without the baffles will result in smoke at idle and part throttle as described before. Not only that, oil has very low octane and can make your engine more sensitive to detonation. Look at the underside of any stamped steel valve cover to see how the factory did it. They were spot welded to the outer shell. This is probably unacceptable since yours appear to be either painted or anodized. You could use some sort of epoxy adhesive to attach a thin metal cover to the underside of the cover.
Re: Can you run Vintage Direct Connection Valve Covers [Re: Kern Dog] #655377
03/30/10 09:41 PM
03/30/10 09:41 PM
Fort Workin Tx
Fort Workin Tx
thanks moparts
Re: Can you run Vintage Direct Connection Valve Covers [Re: Day2Runner] #655378
03/31/10 12:24 PM
03/31/10 12:24 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
I ran a set on my street car. Used baffled grommets and baffled breather caps.
Use good gaskets and hold-downs. The soft alum distorts easily.
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
