02 van won't start and the mechanics don't know why #65401
05/28/08 09:27 PM
05/28/08 09:27 PM
ERIE PA home of the RENCH MOB
mike_vango Offline OP
drove my van to work and when i went to start it again it wouldn't start. the mechanics had it three days, finally thought it was the crank sensor. i went picked it up drove it for a couple miles and it died all of the sudden. this happened before, it wouldn't start then i waited till the next day and it started right up and was fine for months. it's a 360 if that matters. does anyone have any ideas? this is my work van and i haven't had it for 5 days. thanks
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65402
05/29/08 12:37 AM
05/29/08 12:37 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
E coil goes bad often on those. Mine checked fine with a spark tester but would not fire the cylinders.
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: 02 van won't start and the mechanics don't know why [Re: GTX70sixpack] #65403
05/29/08 12:42 AM
05/29/08 12:42 AM
i assume if they where not complete morons they woulda properly checked the ignition & fuel pump.
Re: 02 van won't start and the mechanics don't know why #65404
05/29/08 06:31 AM
05/29/08 06:31 AM
i kinda think they are complete morons. they first thought it was the ignition switch but did not replace it. could the coil or fuel pump not work then work again few days later?
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65405
05/29/08 06:39 AM
05/29/08 06:39 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Yes a coil can fail when hot. Drive it to get it hot and have a helper and a can of either with you. When it dies check for spark at the plug wires if that's not it then spray a little either in the air intake during cranking. Remebr that this will only help narrow the problem down to ignition and fuel systems. It does not mean that the coil or fuel pump are bad more testing should be performed. Intermitant problems are the worst. Crank (or cam)sensors can cause you fits like this in certain models
Re: 02 van won't start and the mechanics don't know why [Re: UCUDANT] #65406
05/29/08 09:52 AM
05/29/08 09:52 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
intermittent problems are tough. Another issue is that those really don't have a couple of known issues. This is going to be a 'pin it down when it happens' deal.
I would check grounds and connections, but it sounds like something is failing open occasionally. You can throw parts at it, or try testing WHEN it's doing it, but otherwise, you are just going to spend time staring at it when it's working like they did. Frustrating, but that's the nature of the beast.
Re: 02 van won't start and the mechanics don't know why [Re: RodStRace] #65407
05/29/08 05:26 PM
05/29/08 05:26 PM
just talked to the mechanic. he thinks its the computer or the ignition switch. he sez there is no spark or fuel and no power to the injectors.
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65408
05/29/08 06:43 PM
05/29/08 06:43 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Key word is he "thinks". They did not fix it so he does not know... I would not put much stock in him at this point.
What sends the signal to the computer to fire the coil and or pulse the injectors? I think you should have a sensor mounted at the transmission mounting flange. If the signal is lost i would expect a code. The computer recieves reference signals and merely interpets the info. No codes stored either? Check pins and grounds wiggle connectors, check grounds as previously stated.
Recently had a GMC that was not injecting intermitantly. A bad temp sensor was the cause. Drive it with a scanner hooked up and monitor refernce signals
Re: 02 van won't start and the mechanics don't know why [Re: UCUDANT] #65409
05/29/08 07:08 PM
05/29/08 07:08 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
ASD relay or trigger will do that too.
Re: 02 van won't start and the mechanics don't know why [Re: UCUDANT] #65410
05/29/08 07:13 PM
05/29/08 07:13 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
And he stated he thought it was the computer or the ignition switch. Did you loose all power when it died? I assume you attempted to crank it again when it died, did it have power?
If it cuts off/dies cleanly as if you shut it down I would suspect ignition. If it sputters and dies I would think fuel.
Re: 02 van won't start and the mechanics don't know why [Re: UCUDANT] #65411
05/29/08 07:20 PM
05/29/08 07:20 PM
yes i was able to crank it. it only died once when it was actually running and it just all of the sudden quit. thanks for this help!
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65412
05/29/08 07:28 PM
05/29/08 07:28 PM
my buddy just called one of his buddies who is an old chrysler tech and he said it is probably the asd relay too. so we will see tomorrow
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65413
05/29/08 08:18 PM
05/29/08 08:18 PM
i just drove over to the mechanics. since the van was outside i swapped the asd relay with the a/c relay and still no start.
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65414
05/30/08 07:48 AM
05/30/08 07:48 AM
any other ideas.
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65415
05/30/08 10:28 AM
05/30/08 10:28 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
Check for power to all these things. Fuses and fusible links will do that as well. Sounds to me like something may have burnt...
2 Demons...no, not my kids!
Re: 02 van won't start and the mechanics don't know why [Re: 4speeds4me] #65416
05/30/08 11:53 AM
05/30/08 11:53 AM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
First thing just listen to hear the fuel pump humming when you turn the key in in the first few seconds when it fails to start (might want to actually have a helper at the tank) if no sound then try swapping the fuel pump relay around to see if that gets it. Then
#1 Good battery voltage and good ground and connections at battery etc?
#2 No stored codes
#3 Is there spark when it won't' start?
If not then you need to determine why, pick up in distributor bad? Do the 2002's run a standard old disributor if so check reluctor gap it should be .008 and needs to be sat with a brass feeler gauge this seems to keep popping up lateley, or do the 2002's have a haleffect sensor? Now the distributor pickup or ASD as previously mentioned or even the crank sensor (mounted at the transmission mounting flange on the pass side upper portion)could cause this but will also effect the fuel system too. Some symptoms of the poor reluctor gap seem to be the vehicle will cut out or fail to start when hot.
If it has spark then it should start if you spray starting fluid in the air intake during cranking? If so suspect a lack of fuel pressure. regulator or pump going bad?
I am home sick so sorry if I don't make much sense today
Re: 02 van won't start and the mechanics don't know why [Re: UCUDANT] #65417
05/30/08 12:33 PM
05/30/08 12:33 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
https://board.moparts.org/ubbthreads/show...rue#Post4419596
Not too likely but maybe your cat convertor is the problemwhen it dies check for glowing exhaust
Re: 02 van won't start and the mechanics don't know why [Re: UCUDANT] #65418
05/30/08 11:27 PM
05/30/08 11:27 PM
P
Paul_Fancsali Offline
P
Having had several dozen 360 vans the biggest culprit period is the ignition coil.They will fail no reason but check the base if the base has any corrosion its bad.
Re: 02 van won't start and the mechanics don't know why [Re: Paul_Fancsali] #65419
05/31/08 11:40 AM
05/31/08 11:40 AM
well the mechanic is hell bent on it being the computer now. he ordered one that will be here monday. he said if it ain't the problem they will eat the computer. i will let you guys know.
Re: 02 van won't start and the mechanics don't know why [Re: mike_vango] #65420
05/31/08 12:24 PM
05/31/08 12:24 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
What has he tested and how?
As said it could be as simple as the coil.
WHEN IT FAILS TO RUN, DOES IT HAVE FUEL OR SPARK?
If you are asking for help here then relpying with what has been tested and tried is the only way to narrow it down. If not no one will be able to assist you. Glad to help, but can't
If I would have gotten that truck in I would slapped a fuel pressure gauge on it and driven it until it failed. Maybe hooked up a Genisys to it and had another tech ride along (we work fleet, and not flat rate)
GOOD LUCK
