Re: Decided the R5 will be going in the Demon
[Re: JLC]
#653695
05/01/10 11:08 PM
05/01/10 11:08 PM
Posts: 2,584 sycamore,ohio
BobsProFab
sycamore,ohio
Bob, can you use some help tomorrow(Sunday)? Let me know.
i can always use a extra hand
[Re: DemonDust]
#653700
05/04/10 05:48 PM
05/04/10 05:48 PM
BobsProFab
sycamore,ohio
waiting on the moly double gusset brackets to show up and then i can finishing the trans crossmember it will bolt in my offset is 12 inches on the crossmember add the seat bar and my 6D and the floor is to 25.3 spec. car still has the front frame rails/fire wall and the rear frame rails / trunk in it and supports from the rockers down to floor no problems with the car trying to spread out. Bob
[Re: BobsProFab]
#653704
05/05/10 07:50 AM
05/05/10 07:50 AM
Posts: 2,813 Blue Ridge, VA
Plumb Wired
Blue Ridge, VA
Bob, run your own rails inside of the stock rails if you want to be sneaky about it or run them beside stock rails. Most of the rules say it must have stock rails doesn't say you can't add. Mike Gray
RIP Monte Smith
aka: OutlawFish '98 Bickel Dodge Dakota PST
[Re: Plumb Wired]
#653705
05/05/10 08:22 AM
05/05/10 08:22 AM
Posts: 3,456 Out West
408strokerdart
Out West
Mike Gray
This is what I did. Then notch the rear frame rails for additional clearance.
