Page 4 of 8 1 2 3 4 5 6 7 8
Re: Decided the R5 will be going in the Demon #653694
05/01/10 10:13 PM
05/01/10 10:13 PM
Columbus, Ohio
JLC Offline
JLC  Offline
Columbus, Ohio
Bob, can you use some help tomorrow(Sunday)? Let me know.
Re: Decided the R5 will be going in the Demon [Re: JLC] #653695
05/01/10 11:08 PM
05/01/10 11:08 PM
sycamore,ohio
BobsProFab Offline OP
sycamore,ohio
i can always use a extra hand
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653696
05/01/10 11:24 PM
05/01/10 11:24 PM
Columbus, Ohio
JLC Offline
JLC  Offline
Columbus, Ohio
Bob give me a call.
Re: Decided the R5 will be going in the Demon [Re: JLC] #653697
05/03/10 08:56 PM
05/03/10 08:56 PM
sycamore,ohio
sycamore,ohio
thanks for stoipping over to lend a hand on the Demon
we did a little floor bar work
Bob
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653698
05/04/10 04:09 AM
05/04/10 04:09 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
What are you doing for a transmission Crossmember Bob?
Alan Jones
Re: Decided the R5 will be going in the Demon [Re: LA360] #653699
05/04/10 06:34 AM
05/04/10 06:34 AM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Did the car spread apart much when you cut the cross member out?
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Decided the R5 will be going in the Demon [Re: DemonDust] #653700
05/04/10 05:48 PM
05/04/10 05:48 PM
sycamore,ohio
sycamore,ohio
waiting on the moly double gusset brackets to show up and then i can finishing the trans crossmember it will bolt in
my offset is 12 inches on the crossmember
add the seat bar and my 6D and the floor is to 25.3 spec.
car still has the front frame rails/fire wall and the rear frame rails / trunk in it and supports from the rockers down to floor no problems with the car trying to spread out.
Bob
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653701
05/04/10 08:29 PM
05/04/10 08:29 PM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Nice work Bondo
Re: Decided the R5 will be going in the Demon [Re: 340RICK] #653702
05/04/10 11:07 PM
05/04/10 11:07 PM
Columbus, Ohio
JLC Offline
JLC  Offline
Columbus, Ohio
I'll be back for more.
Re: Decided the R5 will be going in the Demon [Re: JLC] #653703
05/05/10 01:12 AM
05/05/10 01:12 AM
sycamore,ohio
sycamore,ohio
thanks again Jeff for driving up to lend a hand, hopefully Chris learned a few things.
I still havent decide to keep the stock rear frame rails in the car or not just for a few classes that it can run in
most only care about the front frame rails and fire wall
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653704
05/05/10 07:50 AM
05/05/10 07:50 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Bob, run your own rails inside of the stock rails if you want to be sneaky about it or run them beside stock rails. Most of the rules say it must have stock rails doesn't say you can't add.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Decided the R5 will be going in the Demon [Re: Plumb Wired] #653705
05/05/10 08:22 AM
05/05/10 08:22 AM
Out West
408strokerdart Offline
Out West
Mike Gray
This is what I did. Then notch the rear frame rails for additional clearance.
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653706
05/05/10 10:51 AM
05/05/10 10:51 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Steff had good pics of his round tube rails inside the factory rails from his chally build.
Re: Decided the R5 will be going in the Demon [Re: Bigcube] #653707
05/05/10 11:07 AM
05/05/10 11:07 AM
sycamore,ohio
sycamore,ohio
my 2B bars (rear rails) will run along the side the stock rails
i was thinking of cutting them out for the weight but want to keep the car open to more classes.
Bob
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653708
05/27/10 08:04 PM
05/27/10 08:04 PM
sycamore,ohio
sycamore,ohio
spent a few hours today and tooled up my removable trans crossmember
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653709
05/27/10 08:05 PM
05/27/10 08:05 PM
sycamore,ohio
sycamore,ohio
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653710
05/27/10 08:07 PM
05/27/10 08:07 PM
sycamore,ohio
sycamore,ohio
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653711
05/27/10 08:09 PM
05/27/10 08:09 PM
sycamore,ohio
sycamore,ohio
Re: Decided the R5 will be going in the Demon [Re: BobsProFab] #653712
05/27/10 10:12 PM
05/27/10 10:12 PM
ohio
all spooled up Offline
ohio
Re: Decided the R5 will be going in the Demon [Re: all spooled up] #653713
05/27/10 10:27 PM
05/27/10 10:27 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Dang Bob, that car is gonna be awesome when you're finished...
