Carter AVS Accelerator Pump Part # Or Aftermarket
#651790
03/26/10 11:42 AM
03/26/10 11:42 AM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
Anyone have a seperate part # from a jobber for the Accelerator Pump for a Carter AVS Carb ??? These usually showed up in Carb Kits/Leather Cup, just looking for seperate part # if any
Or
Edelbrock sells like three seperate Accelerator Pumps/Viton Rubber Cup - I guess without having all three in front of me to match up
Thanx Scott Carter AVS #4968s
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: Carter AVS Accelerator Pump Part # Or Aftermarket
[Re: bee1971]
#651792
03/26/10 03:36 PM
03/26/10 03:36 PM
Posts: 5,160 Texas
dannysbee
Texas
One of the Edelbrock numbers works on a early AVS. I have personally used one. Luckily the parts store I dealt with had all of them hanging on the wall and I picked the one that was the closes fit. Sorry I did not save the number.
Getting old just means you were smarter than some and luckier than others.
[Re: Moparmick]
#651794
03/26/10 07:17 PM
03/26/10 07:17 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
Just to pile on, I would like to know this too.
Mark
68 Charger, 383 HP console auto, spring green, stock restoration
[Re: bee1971]
#651799
03/27/10 03:39 PM
03/27/10 03:39 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
SUCCESS!!! The 1470 Edelbrock Acc. pump works! At least it does in a 4640SA off a 69 440. Havent tried anything newer but I beleive the pump well size would be the same anyways. I was a little worried that the new viton seal pump would bottom out in the pump well too soon because of the shape of the bottom of the pump, but the wells have a deeper recess in the bottom anyways, so it worked out. Fly at 'er guys!
[Re: bee1971]
#651803
03/29/10 12:43 PM
03/29/10 12:43 PM
superwrench
Yes....I noticed the difference in length. I installed the plunger with the rod in the top hole of the pump arm.Keeps the pump up farther in the well. Throttle blades opened all the way. Like Scott says, if you're looking to keep the carb's O.E. look, then you would'nt want to use the 1470 pump because of the white plastic stem, but for all around servicability I think the Viton one is superior.
