I am finally getting somewhere!! #651192
03/25/10 07:16 PM
03/25/10 07:16 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Have had the engine in my possession for about 4 years now...finally starting to look like something
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
I am finally getting somewhere!! [Re: knyech1] #651193
03/25/10 07:17 PM
03/25/10 07:17 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Started with above block, and crank from a small block guy on here...
Re: I am finally getting somewhere!! [Re: knyech1] #651194
03/25/10 07:18 PM
03/25/10 07:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Looks,,,,,,,,er,,ahh,,,,,,,,,,,kinda,,,studley
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
I am finally getting somewhere!! [Re: knyech1] #651195
03/25/10 07:20 PM
03/25/10 07:20 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Scat I beams, sealed power rings, and Keith Black 243's (from the same small block guy)...
I am finally getting somewhere!! [Re: knyech1] #651196
03/25/10 07:25 PM
03/25/10 07:25 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
After gapping rings I installed pistons and rods, degreed the cam, put the timing cover and water pump on, bolted the windage tray on, along with the oil pump and pickup...
I am finally getting somewhere!! [Re: knyech1] #651197
03/25/10 07:28 PM
03/25/10 07:28 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Then I had to make an oil pan...which was a long and grueling process not really worth my time. But, like many out there right now, I have more time than money. Started with this. Was actually very grungy and full of sludge but that's pretty typical I guess.
I am finally getting somewhere!! [Re: knyech1] #651198
03/25/10 07:30 PM
03/25/10 07:30 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Then
I am finally getting somewhere!! [Re: knyech1] #651199
03/25/10 07:30 PM
03/25/10 07:30 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
To
I am finally getting somewhere!! [Re: knyech1] #651200
03/25/10 07:32 PM
03/25/10 07:32 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Upon grinding welds down and making it "pretty" it still leaked everywhere and I was unhappy so it sat for a while and the sump was cut off again and a hand made piece was formed...
I am finally getting somewhere!! [Re: knyech1] #651201
03/25/10 07:34 PM
03/25/10 07:34 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Then I was baffled...
I am finally getting somewhere!! [Re: knyech1] #651202
03/25/10 07:35 PM
03/25/10 07:35 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Installed
I am finally getting somewhere!! [Re: knyech1] #651203
03/25/10 07:38 PM
03/25/10 07:38 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Then I cleaned my cylinder deck for the last time, put new dowel pins in, put some head gaskets on, and installed my heads with some head studs...
I am finally getting somewhere!! [Re: knyech1] #651204
03/25/10 07:41 PM
03/25/10 07:41 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
After taking the rockers back on I put the remaining studs in and torqued them down, then checked for pushrod length...
I am finally getting somewhere!! [Re: knyech1] #651205
03/25/10 07:41 PM
03/25/10 07:41 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Close
I am finally getting somewhere!! [Re: knyech1] #651206
03/25/10 07:44 PM
03/25/10 07:44 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Juuust for fun since I don't have my pushrods yet, I had to throw on the intake and carb just to see what it looks like
I am finally getting somewhere!! [Re: knyech1] #651207
03/25/10 07:46 PM
03/25/10 07:46 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Know what, I never posted a pic of the heads that went on...there are a few on Moparts I am sure but I will post anyway.
I am finally getting somewhere!! [Re: knyech1] #651208
03/25/10 07:48 PM
03/25/10 07:48 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Intake runner
I am finally getting somewhere!! [Re: knyech1] #651209
03/25/10 07:49 PM
03/25/10 07:49 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Exhaust bowl
I am finally getting somewhere!! [Re: knyech1] #651210
03/25/10 07:50 PM
03/25/10 07:50 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
Exhaust runner
I am finally getting somewhere!! [Re: knyech1] #651211
03/25/10 07:55 PM
03/25/10 07:55 PM
IL
knyech1 Offline OP
knyech1  Offline OP
IL
To set the correct install heights on the springs, I made my own tool using a 3D CAD solid model program and fabbed it on a lathe. Kinda cool I guess...
