I am finally getting somewhere!!
[Re: knyech1]
#651212
03/25/10 07:59 PM
03/25/10 07:59 PM
Posts: 486 IL
knyech1
IL
So, waiting to get some pushrods as of now, then I will install those, along with the valve covers, and paint the engine. Once dried (of course) I will install the intake manifold and seal it up till the transmission is done and the car is ready...hopefully won't be too long
knyech1-
'71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph
"Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B.
'03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: I am finally getting somewhere!!
[Re: MIKES_DUSTER]
#651217
03/26/10 10:00 AM
03/26/10 10:00 AM
Posts: 2,073 Tulsa, Ok
WadeMetzinger
Tulsa, Ok
Looks really good! I think this motor will make twice the power of your current one.... get ready to hold on
Wade Metzinger 918-809-0987 71 Cuda 9.28@145 -1s, Pglide 68 Cuda 10.64@124 1.45 60's 318->390 eddys Moparts discount code on WIX - moparts www.Filter1.com
[Re: MIKES_DUSTER]
#651223
03/30/10 05:18 PM
03/30/10 05:18 PM
Posts: 486 IL
knyech1
IL
Comp, Cam, Head flow, Etc.. THANKS!!!
Compression ratio is 10.49:1. Heads were cc'ed at 64cc's, and the head gasket I am using is a Fel-Pro Z1008 (.039" compressed thickness). My pistons weighed in at 579.5g, rods were 428.5g (big end) and 165.5g (small end). Hoping to run pump gas but I might not even take my chances.
Cam is a Comp Cams piece, FL 7131 lobe both intake and exhaust. Duration@.050 is 242 and @.200 it is 157. Lobe lift is .360 and with the 1.5 rockers I have the valve lift is .540 at zero lash. LSA is 104 installed.
Heads are 587s. Milodon stainless 3/8" valves with 987 Comp springs (121lb on the seat, 343lb open). They flow about 275cfm maybe a tad more. Vic will be able to tell you more about them, I know that when the ports were roughed in they were sitting at 274cfm.
Intake is an Edelbrock RPM Air Gap and the carburetor is a Holley 825cfm with a Proform main body & baseplate that I got from Keith Dunnuck.
The fuel pump has been blocked off and I will be running a Mallory Comp Series 140 pump I bought off of Myron.
Transmission is an A833 4 speed with an Hurst Indy short throw I bought off of Jeff Patterson. I am wanting to faceplate a couple of gears on it. I already have the flywheel and pressure plate, but need to get the clutch still.
Rear is an 8 3/4 with 742 case. Rebuilt the clutch-type posi unit myself, put 3.91 gears in it (highway gears to Vic ), and bought some high strength alloy axles with green bearings and 3" studs from Dr. Diff.
I scored me some heavy gauge welding wire (#2 maybe? I would have to check) and I am moving the battery to the trunk. Thinking about minitubbing the Duster but I may not want to deal with that. I have an aluminum radiator that I bought and fabbed a couple mounting ears on it just like factory, and I have an electric fan. So the only thing that will be draggin the engine down is the alternator (I have manual steering forgot to mention).
I think that about covers it all. If you want to know something else PLEASE POST!! I really appreciate the interest guys, though I know this isn't really that new and exotic as most guys out there. I am flattered some are still interested. Any thoughts about anything too feel free!
knyech1-
[Re: MIKES_DUSTER]
#651225
03/31/10 02:29 AM
03/31/10 02:29 AM
Posts: 486 IL
knyech1
IL
You're welcome! Glad to post! I will eventually have more as I progress with the project. I will bump it when I get it going for maybe a sound/video clip and some time slips, maybe a dyno run we will see. Hopefully not too far down the road.
knyech1-
