1972 340 Demon manual 10" brake questions. #651108
03/25/10 05:28 PM
03/25/10 05:28 PM
Ont Canada.
Hardcharger65 Offline OP
Ont Canada.
Can the front manual small bolt pattern 10" front drums and hubs on my 72 Demon be redrilled to the 4.5 " large bolt pattern ?, is it possible as ive been told it isent ??. Also can the rear axels be redrilled to 4.5 " again ive been told there isent enough material to do it the studs would be far to close the the outer edge of the axel and wouldent be safe to drive daily due to lack of strengh in the axel face .
Re: 1972 340 Demon manual 10" brake questions. [Re: Hardcharger65] #651109
03/25/10 06:31 PM
03/25/10 06:31 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
i had my front and rear redrilled by Moser engineering.
this was done almost 9 yrs. ago.
i've never had any problems.
any competent machine shop should be able to do it.
Re: 1972 340 Demon manual 10" brake questions. [Re: ohiodemon] #651110
03/25/10 08:29 PM
03/25/10 08:29 PM
Happy Birthday RapidRobert  Offline
Drill/tap the SBP rear axle flanges for screw in 1/2" studs rather than press in which leaves an adequate amt of material than the slightly larger dia required for press in studs.
