My a/c was leaking on my 2000 Neon and I found the leak way back at the firewall. It is coming from behind the aluminum block right at the firewall.
Does anyone have a picture they could blow up of this area? I am hoping it may be a gasket, but I am not sure if there is another connection behind the one main connection at the front part of the aluminum block where the hoses mate.
Also, how much of the dash will have to come out to get to the evaporator?
