Page 4 of 6 1 2 3 4 5 6
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: hemi-itis] #649374
03/27/10 10:04 PM
03/27/10 10:04 PM
Westbury, NY
cowbay Offline
cowbay  Offline
Westbury, NY
The SV1 utilizes a single venturi with special port layouts and very high cfm ratings that were previously unattainable. Due to its high amounts of signal and shift recovery the SV1 uses 4150 style 2 circuit metering blocks and gaskets. There is no intermediate circuit required to assist in throttle response and shift recovery (like most 1050 cfm and larger four barrels prefer and require).
The unique quadrant tuneable SV1 booster design (which allows your main jetting to effect each quadrant or corner of the carburetor) has an exceptionally low lift point and the throttle shaft and blade does not impede signal generation, so the SV1 offers previously unattainable levels of low speed and shift recovery signal.
As you roll into the throttle on other designs, the throttle blade is in the way of the booster until it gets to wide open throttle. On the SV1, the booster begins receiving signal the moment the blade even begins to open. This offers faster priming of the metering system so the SV1 will jump right up on even the tightest converters. It also gives the SV1 incredibly smooth and very nice driveability. You will be impressed by how nice the design drives and idles.
The amazing idle quality is simply a result of a better layout. You see on four barrel designs, the backside of the blade only allows in "clean air". You really only have an opening at the front and rear of the blades to atomize the idle fuel, the sides of the blades (inline with the shaft), stay snug to the venturi at all times, acting like a divider. But there is another divider. On all four barrel designs, zero or very little fuel can make it to the opposite side of the blade as the throttle shaft acts like a drip rail and (divides) cuts the fuel off from traveling to this "clean air" side. So on four barrel carburetors, only the outside edge of the blade gets fuel. The inside edge towards the center of the body gets no fuel and only passes (or mostly passes) clean air into the engine. So half of the air entering the engine is improperly lean. To compensate, on four barrel carburetors, the fuel port side of the blade must be kept improperly rich to get a good "average".
Clean air is the enemy in an engine as it typically stays clean as it easily travels through the intake in the direction of any cylinder or cylinders it wishes to feed.
On the SV1 the front half AND the rear half of the blade are exposed to fuel delivery ports so there are no "clean air" openings available to bypass these idle fuel ports (so no stray "clean air" streams can occur). On the SV1, every place where air comes into the engine, offers mixture screw controllable atomized fuel (it's also unblocked as there is no throttle shaft divider keeping half of the blade from access to a fuel port). This idle fuel is then drawn around the perimeter of the very large blade and is atomized over this very large surface area and that really improves the idle quality and evens up the distribution.
This much improved idle quality/atomization configuration is very important to Nitrous applications as it keeps your cold nitrous plugs from fouling out, so they stay clean and ready to go. It's great for street and bracket racing/throttle stop cars too.
Another advantage to the single blade design is also obvious. Four barrel carburetor designs require the throttle shaft and blade to be located directly under the center of the booster. This layout impedes the boosters ability to quickly respond to air speed changes. The SV1 uses a booster design that does not rely on a signal generating center (like an annular, aerosol or dog leg booster). So on the SV1, the throttle blade and shaft location are no longer a factor. On the SV1, the whole booster length generates signal and because the blade and shaft are no longer a "signal blocker", when air speed suddenly changes (during a shift or the engagement of nitrous) you get more instant response to these changes and faster shift recovery time as a result. This reduces lean spikes. So you can stand on your nitrous tune up even harder without worry of going lean on the shifts or during nitrous engagement and encountering a loaded nitrous backfire. This also makes the carburetor very consistent for bracket racing and throttle stop type applications as well.
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>From the Prosystems web site
It is like you are talking dirty to everyone here on the board along with blowing into our ears
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: cowbay] #649375
03/30/10 05:26 AM
03/30/10 05:26 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
hemi-itis how big is your throttle blade? I have a un-molested 440-3 and curious about clearance
Mopar Performance
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: moparniac] #649376
03/30/10 09:34 AM
03/30/10 09:34 AM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I just saw in the 2010 NMRA rule book that if anyone is running the SV1 they will have to add 25 pounds to the car.i guess that says a lot about the carb.i have a prosystem dominator but I don't see me buying the sv1 carb but you never know
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: Otherlane] #649377
03/30/10 10:46 AM
03/30/10 10:46 AM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Ordering one with 110mm blade this week,hardly wait to try it..
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: jb15] #649378
03/30/10 03:46 PM
03/30/10 03:46 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
the SV1 wont clear with a 440-3. needs modded for sure. patrick list this on his site now about dart cloverleafs but the indy aint gonna fit either! not without mods anyway!
anyone wanna trade for an unmolested indy 440-3
Mopar Performance
Re: PRO SYSTEMS SV1,,,A WORK OF ART #649379
03/30/10 04:22 PM
03/30/10 04:22 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I'm not saying it's a bad piece, and it may be better out of the box for the average Joe that doesn't understand carbs, but to say it's got better throttle response than a tuned Dominator is stretching it.....
We can all take stabs in the dark and have a good 50% chance of being right...
Myself,,, I'd like to hear somebody that bolted it on, and tried it. And I don't give a turd about idle, Its the whole response and staging and driving around thats important. I believe it could make more horse power, but hows the manners.
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: RemCharger] #649380
03/30/10 07:06 PM
03/30/10 07:06 PM
You don't care about idle? You don't care about fouling plugs, but you care about part throttle driveability??? that makes a lot of sense.......
Come to Oklahoma and I'll take you for a ride in my GTS Dart with a Dominator........It fires up at the crank of the key, idles like a kitten, has awesome throttle response, and drives around smoothly like a two barrel.......
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: cowbay] #649381
03/30/10 07:29 PM
03/30/10 07:29 PM
canada,NB
jb15 Offline
jb15  Offline
canada,NB
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: jb15] #649382
03/30/10 09:11 PM
03/30/10 09:11 PM
Great Neck,LI,new york
hemi-itis Offline OP
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: PRO SYSTEMS SV1,,,A WORK OF ART #649383
03/30/10 10:42 PM
03/30/10 10:42 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Hey, thanks for the invite! I'd like to take you up on the offer, I'm sure It does everything you say and more. And I'm by no means knocking your tuning skills, I don't even know you.
Alls I'm sayin' is this thing might not be a turd. I'd like to see if it is what they say it is. I was trying to talk one of my sponsors into Getting a "demo"
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: RemCharger] #649384
03/31/10 10:30 AM
03/31/10 10:30 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
I had the chance to try one this past Thanksgiving at a race I traveled too in Abilene. Unfortunatley I didn't get to play with it much. I can tell you that the idle is good, the driving around the pits is very good, and the throttle response is insane! I was -.041 red with it footbraking seeing the last yellow bulb. The testing session was cut short so I had to put my 4500 1050 back on for the actual race. I sent it back to Patrick because I was just a test driver for him. He said he wanted to make some changes to it and send it back. He informed me yesterday that he has been very busy and I should see the sv1 sometime next week or so.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: Otherlane] #649385
03/31/10 10:42 AM
03/31/10 10:42 AM
Westbury, NY
cowbay Offline
cowbay  Offline
Westbury, NY
Well if that does not say something positive, I do not know what will
"Alcohol is for drinking, gas is for cleaning parts, and nitro is for racing!" original author unknown, used by Gene Adams and Don Garlits among others
Re: PRO SYSTEMS SV1,,,A WORK OF ART #649386
03/31/10 10:43 AM
03/31/10 10:43 AM
under a rock
flathood Offline
flathood  Offline
under a rock
I thought winter was over, especially in Oklahoma.....
It actually snowed this past Saturday and Sunday, but the track was open today for TNT.....
I just spoke with Joe Nova,he bolted the SV1 on his car,,,,,,couldn't wait for me.Set the idle air screws,the floats were right on .The old carb liked an 1100 rpm idle.The SV1 idles at 800 rpm.Rise time real quick,took it for a blast.There is a new problem.The 18 x 33's won't stay stuck gunna have to try the slicks
If it idles at 800 now and was at 1,100 before, that just says he had the wrong carb before and/or didn't know how to tune the one he had.....
....I guess 2 SV1's will be way too much CFM for my conservitive build
I agree.....9.90's out of a blown Hemi is pretty conservative.......
Wayne
From what I've read about that blown HEMI,it's 13% underdriven with tiny holley 750's and 5 lbs of boost.Sounds more like a conservitive tune up.That combo could make upwards of 1400 hp with a pair of SV1 carbs and some overdrive.
Re: PRO SYSTEMS SV1,,,A WORK OF ART #649387
03/31/10 10:58 AM
03/31/10 10:58 AM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
Sounds like a good peice but what do I know.
I do know that I would love to take you up on that offer if I was closer. I would have to bring my car as well because my dominator doesn't do any of what you listed except run well wide open.
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: flathood] #649388
03/31/10 11:26 AM
03/31/10 11:26 AM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Wayne
1400 Horse ?? not in a million years. I love how people throw out these huge huge horsepower estimates for roots blower motors. it might make 1400 horsepower with a 1471 blower and alcohol. I have worked around big roots blower motors used in offshore powerboats for a long time. It takes those guys big inch, big cheif head, 1471 intercooled, dominators, race gas, and still not make 1400. I better get on the phone now and start telling those guys not to spend 50 K a motor to make 1100 horse, when all along it only takes a 426 hemi with an 871 and sv1's.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Post deleted by Defbob [Re: HemiDart68] #649389
03/31/10 12:04 PM
03/31/10 12:04 PM
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: RonP] #649390
03/31/10 01:26 PM
03/31/10 01:26 PM
My Dominator has been conservatively tuned up by Porter for my combo.......All I had to do was jet it.......
Re: PRO SYSTEMS SV1,,,A WORK OF ART #649391
03/31/10 01:46 PM
03/31/10 01:46 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
we made 1180 hp all motor
With a 426 ? apples to oranges. I was referring to the HemiItis motor making 1400 horsepower with a pulley and carb change.
Re: PRO SYSTEMS SV1,,,A WORK OF ART [Re: HemiDart68] #649392
03/31/10 04:32 PM
03/31/10 04:32 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
making 1400 for 1 hr is not like making 1400 for 8sec. at a time. you would just call it fake if some1 did make that much i think.do you realy think that 1400hp cant be made with a combo like his? i am not trying to cause trouble just debate a little.
Re: PRO SYSTEMS SV1,,,A WORK OF ART #649393
03/31/10 10:11 PM
03/31/10 10:11 PM
