Re: PRO SYSTEMS SV1,,,A WORK OF ART
[Re: MR_P_BODY]
#649334
03/24/10 12:16 AM
03/24/10 12:16 AM
Posts: 2,524 PA
moparacer
PA
I think the fuel pressure has to rise as the demand for fuel rises.Something like 11 PSI or something.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#649335
03/24/10 12:44 AM
03/24/10 12:44 AM
Posts: 52,972 Romeo MI
MR_P_BODY
That would be pretty hard to do... it cant see a pressure to increase the reg pressure(like a turbo reg)... but what do I know
[Re: topbrent]
#649339
03/24/10 08:32 AM
03/24/10 08:32 AM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Just got mine. We are going to dyno it as soon as the shop has an opening. Our 417 W-8 made 861@8200 w/a 4150......1.590 hole/1.750 blade. It is a nitrous style build. 420 intake w/4150 to 4500 adapter for the SV-1. I'll post when the results are in.
[Re: topbrent]
#649340
03/24/10 08:35 AM
03/24/10 08:35 AM
jim sciortino
Trumbull,CT.
Without searching for the info on my part, what is the real benefit and ideal application for a carb like this?
Suitable for street/strip type stuff?
Race only?
Is full throttle operation the main benefit?
Not just a race carb.
Tip in and part throttle are supposed to be outstanding.
We'll see.
[Re: jim sciortino]
#649341
03/24/10 08:37 AM
03/24/10 08:37 AM
MR_P_BODY
Just got mine.
Our 417 W-8 made [Email]861@8200[/Email] w/a 4150......1.590 hole/1.750 blade. It is a nitrous style build.
Just curious if you could make a pull with and without the adapter since I guess it can be bolted up to a 4150 or 4500 manifold... I'm curious if the 420 needs the plenum volume of the adapter... I have the 420 but I machined it to take a 4500 without the adapter.... thanks (if you can)
[Re: MR_P_BODY]
#649342
03/24/10 08:48 AM
03/24/10 08:48 AM
jim sciortino
Trumbull,CT.
Just got mine.
We need the adapter. our 420 is a 4150 top and the SV-1 blade will not clear. We didn't go with the 95 blade. Pro Systems sell an SV-1 that will clear though.
[Re: moparacer]
#649347
03/24/10 03:04 PM
03/24/10 03:04 PM
Posts: 6,295 U.S.
moparniac
U.S.
I talked to patrick and he says hogwash on the special reg.! he does sell one for alcohol and E85
Mopar Performance
[Re: hemi-itis]
#649348
03/24/10 10:32 PM
03/24/10 10:32 PM
Posts: 8,182 Detroit, MI
CokeBottleKid
Detroit, MI
They sell for $1150 each + extras I was just reading on YB that the PRO SYSTEMS fuel regulator is needed with this carb http://yellowbullet.com/forum/showthread.php?t=203896&highlight=pro+systems+carbs&page=6
I just don't see the point anymore these days, you could have a nice mega-squirt setup and make the same power with much better manners for the same price (maybe less)...
[Re: moparniac]
#649349
03/24/10 10:48 PM
03/24/10 10:48 PM
Posts: 867 Bellevue, NE
Charger453
Bellevue, NE
So he's saying you don't need it??? I emailed him about a normal 4150 E85 carb telling him I'd make 600 HP N/A and hit it with 150-200 of N2O from time to time and he recommended the regulator. He said I'd be borderline needing it/not needing it.
[Re: CokeBottleKid]
#649350
03/24/10 10:49 PM
03/24/10 10:49 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
How much is their system with all the sensors,computer etc that can flow up to 2800 cfm??
