340 idleing rich #64804
05/27/08 08:07 PM
05/27/08 08:07 PM
ohio
dodgedart416 Offline OP
ohio
What could cause this? Runs great plugs look good after drive (shut off immediately after drive).Has edelbrock carbs (2) adusted them all over per edelbrock any one have any idea? Thanks
Re: 340 idleing rich [Re: dodgedart416] #64805
05/27/08 08:40 PM
05/27/08 08:40 PM
Prescott Az
73 SSP Offline
73 SSP  Offline
Prescott Az
r u running mechanical or electric fuel pump?
Might be fuel psi to high.
Re: 340 idleing rich [Re: 73 SSP] #64806
05/27/08 09:15 PM
05/27/08 09:15 PM
California
P
polkat Offline
mopar addict
polkat  Offline
mopar addict
P
California
I'm having the very same problem with an Eddy 1406 on a 318 with standard mechanical pump, and have had the same problem with Edelbrocks in the past. I think they just idle rich.
Re: 340 idleing rich [Re: polkat] #64807
05/27/08 09:26 PM
05/27/08 09:26 PM
ohio
ohio
I have elec pump and fuel pressure gauge. Pressure is set at 6 psi
