Edelbrock 600 carb question #648030
03/22/10 02:58 PM
03/22/10 02:58 PM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Will the EGR provisions on an Edelbrock model 1400 reduce performance compared with a model 1405 or 1406? Thanks
Re: Edelbrock 600 carb question [Re: alpha727] #648031
03/22/10 07:29 PM
03/22/10 07:29 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
isnt it same carb calibrated differently?
Re: Edelbrock 600 carb question [Re: 05dakota] #648032
03/22/10 07:58 PM
03/22/10 07:58 PM
Connecticut, USA
sixty7gtx Offline
sixty7gtx  Offline
Connecticut, USA
I think so not sure,
1967 Plymouth GTX,
1968 HEMI, 4 Spd. Super Bee,
2010 Chrysler 300 Touring,
MOPAR = Machines Of Performance And Racing!!
Re: Edelbrock 600 carb question [Re: alpha727] #648033
03/22/10 08:13 PM
03/22/10 08:13 PM
The EGR (exhaust gas recirculation) capabilities would in the intake not the carb where the egr (vac valve) device can bolt to the side of the intake w 2 bolts to recirculate a certain amt of ex gas. It helps emissions (NOX iirc) but any dilution of the air/fuel mixture w ex gas will cost you power
Re: Edelbrock 600 carb question [Re: RapidRobert] #648034
03/23/10 01:30 AM
03/23/10 01:30 AM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
The intake I'll be using won't have provisions for EGR I was planning on just bypassing all of it. Can anyone tell me if the springs and metering rods are interchangeable between the three carbs? (1400, 1405, and 1406) I know the 1400 is setup to be a 50 state legal carb and Edelbrock doesn't directly offer a calibration kit for it but was wondering if another Eddy 600 calibration kit would work with it. Thanks.
Re: Edelbrock 600 carb question [Re: alpha727] #648035
03/23/10 08:27 AM
03/23/10 08:27 AM
NY usa
540challenger Offline
NY usa
The springs will work between the carbs As for the rod i know the 1406 and 1405 use different rods in the calibration kit. I would check to see what jets are used in each carb on-line at eddy's site to see if it is the same for the 1406 and 1405. Heck i am they are all the same cfm you could just order the stock jets from a 1406 "fuel mileage carb"tuned or 1405 "performance" tuned swap them in and then order the calibration kit for whichever carb you choosed to copy off.
Re: Edelbrock 600 carb question [Re: 540challenger] #648036
03/24/10 01:55 AM
03/24/10 01:55 AM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
I researched the information on Edelbrocks website regarding the 1400, 1405, and 1406 carbs. All performer series jets, metering rods, and springs are interchangeable. I looked at the differences between the 1405 and 1406 calibration kits and it appears that the 1405 just includes a bigger assortment of jets, rods, and springs than the 1406. So I should be able to tune the 1400 with the 1405 kit. It looks like the only real difference between the 1400 and 1405/1406 is that the 1400 has a canister vapor vent for EGR. I think the 24 bucks I paid for the carb might have been worth it. Thanks for all the help.
