Re: speedo gear alignment pin??
[Re: Pacnorthcuda]
#64771
05/27/08 08:28 PM
05/27/08 08:28 PM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
I can't think of anything that a person would describe as a pin in these things.
There is a hole in the trans housing that is in alignment with the speedo gear, or at least that is what it looks like.....
[Re: Dart 340]
#64773
05/27/08 09:24 PM
05/27/08 09:24 PM
ANOTHER case where a Factory Service Manual would come in handy! (Or a fellow moparts user who is willing to learn some new software to bring you a picture,)
#64774
05/27/08 09:38 PM
05/27/08 09:38 PM
Whoops, that pic and text is from the TorqueFlite section, but a quick look at the 833 section shows a different picture, but about the same text. I got a bum left leg out of the Navy, and when I think transmission, it always comes out TorqueFlite. Like I said at the top of my last post.....Factory Service Manual.
#64775
05/27/08 09:45 PM
05/27/08 09:45 PM
#64776
05/27/08 10:51 PM
05/27/08 10:51 PM
Dart 340
moparts member
moparts member
The other picture!
There is a hole inside the transmission that looks like it aligns with the plastic part of the gear which also has a hole in it. I was thinking it was a support pin which might hold the rear of the gear opposite the front which the speedo cable goes into. You cannot see the hole unless the gear is removed.
[Re: Dart 340]
#64777
05/27/08 11:06 PM
05/27/08 11:06 PM
Posts: 18,427 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The other picture!
Listen......There is no pin. the pics posted show everything. The gear is held in place by the adaptor. The gear can only go so deep into the tailshaft housing as its machined.
Post pictures of what you are looking at....
[Re: NITROUSN]
#64779
05/28/08 10:01 AM
05/28/08 10:01 AM
Dart 340
moparts member
moparts member
The other picture!
Ok, so what does the end opposite the speedo housing go to. So you are saying it floats loose? Then it is only supported by the housing its self. So then is there a thrust button in the trans that keeps the gear from floating front to back?
[Re: Dart 340]
#64780
05/28/08 10:02 AM
05/28/08 10:02 AM
Dart 340
moparts member
moparts member
The other picture!
[Re: Dart 340]
#64782
05/28/08 10:19 AM
05/28/08 10:19 AM
NITROUSN
No thrust button. Nothing period. Just put it togeather.
[Re: stumpy]
#64783
05/28/08 10:28 AM
05/28/08 10:28 AM
Dart 340
moparts member
moparts member
THERE IS NO PIN. Quit trying to make a ten minute job into a project.
I'm not trying to.
Look guys, I'm a mechanical engineer that worked in automotive for 15 years.
Ok get your slams out of the way....
Now that said, if there is not a thrust button to control the end play on the gear, and no support on both ends of a driven gear, it's a pretty crappy design. Period.
No wonder they make one sacrificial...........
[Re: stumpy]
#64786
05/28/08 10:33 AM
05/28/08 10:33 AM
Dart 340
moparts member
moparts member
It just amazing that they last 20-30 years considering how badly you say the are designed.
Some do, aaannnnnddd some don't.
